Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
911 on a rotisserie
Anyone that might tell me where the Center of Gravity is on a 911 bare chassis.
I am in the process of building a simple rotisserie for my 1972 911 coupe and some dimension say off the bottom pan of the car to the rotation axis of the rotisserie would save me having to build in a lot of adjustment range.
A picture of a 911 on a rotisserie would even get me close enough.
Old 12-06-2010, 10:10 PM
300hp 1800lbs is the goal
pksystems's Avatar
http://forums.pelicanparts.com/porsche-911-technical-forum/228044-flanks-71-targa-911-rotisserie-pictures-plus-plans-so-you-can-build-your-own.html
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 12-07-2010, 03:50 AM
robmog's Avatar
flank's work is impressive, but overkill?
i made mine from 2 engine stands and some 2" square tube.
these are the best shots i could find, hope it helps.
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 12-08-2010, 05:28 PM
pksystems's Avatar
I used a couple cheap engine stands and and some scrap steel from the recycling bin
Unfortunately I didn't make mine quite high enough so I can only go like 130 degrees before the top edge of the roof makes contact with the joiner. I can probably go 180 if I remove the joiner.
I used a cheap winch on each end to hold positions/help turn the car.
Old 12-09-2010, 04:21 AM
Formerly reformed
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/524957-garage-barn-find.html
1968 911P (Paperweight)
Old 12-09-2010, 07:39 AM
Bird. It's the word...
Fishcop's Avatar
It's lower than "middle" or centre axis... as most of the chassis metal is in the floor/sill/inner rails.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 12-10-2010, 04:59 AM
Tim Boyer's Avatar
Fishcop,
Can you tell me the name or code of the color that is on your car? It is an awesome shade of blue/purple!
Thanks,
tim
Old 12-26-2010, 11:45 AM
