Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Melman's Avatar
Sunroof help
1977 911 Just opened my sunroof ....and it seems to be stuck in the fully open position....it feels like it is caught on something at the back.... has anyone had a similar problem or any hints on how to resolve this .....I want to drive it but its a rainy fall .
Thanks Jon
Old 10-16-2011, 06:23 AM
Sunroof
Have you tried to crank it by hand at the transmission in the roof?
If it can't be cranked there is the possibility that a cable broke.
Has the motor sound changed. There is a " flexible drive shaft" between the motor and the sunroof transmission, check it.
Good Luck.
Gene
63 B coupe
64 SC sunroof
912 coupe (current)
914/6 (current)
Old 10-28-2011, 11:24 AM
I have a similar problem with my sunroof , its won't open seem to be stuck at one sides.
Old 11-15-2011, 11:41 PM
newby
Aussie Thunder's Avatar
I had this problem, I had to unzip the zip and remove the gears, realign the roof manually then put the gearing back in - all sorted ! Now I don't go to full open just in case !
There is a thread on this fix, just not sure where ...
Ben
1989 Black 930 3.3 964 Turbo Motor 5 Speed
Ben Clark Photography
Website: http://www.benclarkphotography.com.au
See our latest work:http://www.benclarkphotography.com.au/blog
Associate member of the AIPP - Aust Inst of Professional Photographers
Old 11-16-2011, 12:23 AM
