Rotisserie and unabody bracing
I wanted to get some feedback about something 962porsche posted in the rotisserie thread
First of all, my tub is still on blocks, leveled and receiving a new left inner and outer rocker along with some adjacent metal. I will measure it before it comes off the blocks for a base line and to determine if it's close to square out of the gate. My formidable search foo is weak as I've found no procedures or explanation of how to "square up the car" or even measure it for squareness. Can someone please explain this in better detail? Once square, how do you suggest a DIYer properly brace a tub? I understand front to back, left to right, trunk, cabin and engine compartment. Do I just start welding "X" patterns across door jambs and all three compartments? Anyone have pictures of a properly braced tub? What would you recommend a DIYer use for bracing?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Bird. It's the word...
Hi Tharbert
I replied to your PM, but here's some pictures. The octisserie format is very unibody "friendly", but definitely brace it up before the sills, floors or other structural elements are removed. And do it one side at a time. ![]()
John Forcier Current: 68L 2.0 Hotrod - build underway |
I think I went a little overkill on my bracing.
dkbautosports.com
to square up a car or to check to see if it is . you need the chasses measuring guide of the car so you can check the measuring points . a measuring guide gives you all the places to measure from and to . we do this to all our cars that are getting a resto . if the car is out of it's meaurements at all from spec we them mount the car on the celette bench and give it a pull into spec . if a car is mounted and you brace the crap out of it you can do the work on a rotisserie . i have found over the year of doing resto's it's just not worth it . we have a car right now in the shop that the customer did the resto on him self with the car on a rotisserie . he braced the crap out of it and the doors he can't get the gaps right . the car is out of spec by 1.8 mm . you may not think it's much but it makes it a total of 4.3 MM out . you only have 2.5 MM + and - making it a total of 5MM to be in spec . the sad thing is when the car was turned up side down the tops of the door gaps opened .
dkbautosports.com
dkbautosports.com
john's rotisserie is a good one . this does not hold the car on both ends only . were the car bolts up to the rotisserie is one of the best places to bolt a car up to one .
But strange, when I cut the roof off there was no spring in it and the other roof fit perfectly. Some maybe it did "cut it". Either way I didn't take any chances and made sure to square up the car by it's pick up points before finalizing all my cross bracing and stitching the roof on. |
dkbautosports.com
the car should not sag much or at all by removing just a roof skin . it's when the car get's cut up like John's blue car posted here . cars are built on jigs there for i also like to repair them the same way . if you want to do a resto on your car using a rotisserie thats just fine with me . i have stated many times the good and bad about using one and feal no need to get into that again .
I wouldn't imagine the pros using a tape measure? On your customers car, was it something a novice could spot with the factory service manual measurement pages with the car on jack stands? Last edited by CalvinC4S; 12-20-2011 at 12:44 AM.. |
dkbautosports.com
you use a tram gauge to do the measuring . there about 200 dollars for a starter one . if you look at what they real are you can make one your self for about 30 dollars . as we put the panels back on the car we also keep taking measurments to know the cars going together with in the car makers spec .
