paint system
Hi,I just stripped a fender to bare metal.Can I epoxy primer with some leftover nason epoxy primer or do I need to buy my complete painting system now and use the " " that comes with the system?Thanks,T.C.
dkbautosports.com
i see no reason why you can't use your old nason epoxy primer if it's still good . it's good idea to stay with one system but if your not mixing primers and top coats from every other system out there you should be ok . also you don't have to buy every thing all at one time . if you pick a system and only need the e-primer now them just buy that . later on when you want a filler primer you can just go back to the jobber and get that .
