Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
lespaul's Avatar
78 SC - small surface rust spots question
My 78 SC has a half dozen small spots on the exterior where the paint is either chipped through or somehow worn through. None are bigger than a half dollar. Some are along the hood edges or door edges. One concerns me that looks like a bubble of rust along the edge of the rear window seal.
I don't plan on painting the car for 2 or 3 years, but would like to attend to these small spots now. Normally, I would sand them down and prime them and let it be until I got around to a full paint job. But, with the galvanized body, I am concerned about sanding off the protective coat.
Suggestions?
Brad
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 08-04-2015, 10:24 AM
dkbautosports.com
962porsche's Avatar
every one is so concerned about the galvanized coating porsche uses .
it's nothing special or different then every other auto makers !
you touch it in any way with sand paper at it's sanded right off the car .
to replace it you use a epoxy or etch primer !
if you have rust the galvanized coating is long gone were the rust is and for about a 1/4 inch around it .
primer in no way will stop the rust from coming back !
primer doesn't hold out any moisture at all in any way you will need to got some type of top coat on the primer .
Old 08-04-2015, 02:20 PM
lespaul's Avatar
Thanks 962. I just want to make sure I understand. Go ahead and remove any rust with sand paper, then prime with an etch primer, then top coat the primer. Might looks spotty until I do a proper paint job but that will be ok until then?
Brad
Old 08-05-2015, 06:32 AM
Go get some two part epoxy primer and paint, it will hold up better than spray cans especially if your gonna wait 2 or 3 years to paint your car. You'll need more than sandpaper to remove as much rust as possible.
Old 08-05-2015, 07:39 AM
dkbautosports.com
962porsche's Avatar
that is some thing if you can't get the rust off by sanding you may want to think about spot blasting with a hand held blaster or use a rust convertor on .
Old 08-05-2015, 11:44 AM
