Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Fender Panel Gap Help
I'm currently working on fitting a pair of Dansk fenders to my '77 but struggling to get the panel gaps perfect. There is some adjustment in the fenders, but after several hours this is the closest I can get.
Is there something I'm missing? Is the next step adding or removing metal? Thanks!
Driver's side:
Passenger side:
Old 04-07-2016, 06:03 AM
I could use this info too!
Old 04-20-2016, 12:26 PM
dkbautosports.com
962porsche's Avatar
don't be bashful to bend the panel that the fender bolts up to that runs down the A pillar .
if it needs to be moved forward or back to align the panel gap then that is what you have to do .
a block of wood and a BFH will move it easy .
Old 04-20-2016, 12:36 PM
I'm in the midst of adjusting my drivers side door too. The factory manual shows how to move the door back and forth by using a hammer and a piece of hardwood. You can also shim behind the hinges and there is movement in the hinges too. I'd be interested to know what the factory did. I'm guessing they got it close with hinges and then used the hammer and wood to get the door centered back and forth.
__________________________
'18 Macan S - my turbo Porsche
previous Pcars
'58 356A coupe, '00 Boxster S;'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E
Old 04-24-2016, 06:47 AM
78-911SC's Avatar
Obscene can you give use some pics of the margins on the trailing edge and rocker panel of the door? Ditto on what 962porsche said.
PJ
78 911sc Targa
70 911T
Old 04-24-2016, 07:35 AM
Yeah you really need to size up the whole perimeter to see what needs to be done.
previous Pcars
Old 04-24-2016, 08:48 AM
Hmm I don't think I have any full side shots. The doors haven't been off though and have great gaps along the rocker and trailing edge.
Old 05-03-2016, 08:49 AM
Fixer's Avatar
Obscene,
Get them fitted as told to you above. Leave the doors alone bc they're right.
Once the fitment is right w a 3mm [nom] gap, do not use any adhesive and or sealant between the fenders and tub because when i have the spare time i will paint your fenders right for you free of charge, just do the sanding and provide the paint.
Matt
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 05-14-2016, 03:00 PM
Thanks, Matt!
Old 05-16-2016, 09:49 AM
