Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
techweenie's Avatar
LED replacement H4 light
Doing some work on a 356B. Planning to replace the H4 bulbs with LEDs.
Anyone have experience with LEDs in this application?
They don’t seem to be voltage-sensitive, so 6v supply doesn’t require a specific part
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-27-2023, 07:40 PM
Go to the 356 Registry website and their Talk section. There are many threads about LED lighting.
Old 10-29-2023, 08:50 AM
techweenie's Avatar
I only found threads about LED signal & brake lights. Not headlights
1969 coupe hot rod
Old 10-29-2023, 10:39 AM
Try Classicowheels.com.
Old 10-30-2023, 10:59 AM
I had the classicos, they are "blue" and can't be adjusted properly - it is just useless light. Go to the vendor forum on the 356 registry for alternatives. Most will not work on 6v, as you only get 5.5ish at the headlight socket unless you install a headlight relay. They will go out when you sit idling at a light if they work at all.
Old 11-06-2023, 01:06 PM
Mr. Merk's Avatar
Oh gosh, stop. Do not pass go, do not collect $200.
https://www.danielsternlighting.com/products/products.html
Send Dan an email at ( dastern@torque.net ) and he'll put you on to the best options for your 356
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 11-06-2023, 02:08 PM
You are seriously comparing Halogen to LED? Halogen was a great alternative to stock lights, about 40 years ago.
Old 11-06-2023, 02:29 PM
Mr. Merk's Avatar
Certainly a quality H4 lamp with a quality H4 bulb is going to be far superior than any LED in any H4 halogen lamp.
However, a Philips, JW Speaker or Truck-lite branded LED lamp is superior to probably any halogen H4 lamp configuration. They just don't look anything close to period correct in my opinion. Putting a fluted lens over an LED lamp is going to negate any improvement you're trying to accomplish.
6V certainly makes things more interesting, but I'm sure Dan has a viable solultion.
Old 11-06-2023, 02:59 PM
There are indeed limits to what a 6v 356 can do. The biggest one is the 200w generator (or 160w in an A). Installing two 55w (or even worse, 90w) H4 bulbs to get brighter lights will ruin your regulator and generator in the not too distant future as you are overloading the output by quite a bit as soon as you turn your lights on. Then next will be the Bakelite around the light switch and the wiring around the various bullet connectors that will melt.
Old 11-06-2023, 03:13 PM
Bill,
I’m thinking John Audette can point you in the right direction. Probably, you already know that.
https://911bestinclass.com/collections/currently-featured/products/on-sale-copy-of-ac-series-3-led-headlights
Regards,
Bill C.
Old 11-12-2023, 07:48 AM
Last time I checked with John he did not have 6v. It's been a while though. Vintage Trader has the most authentic looking 6v LEDs. They are warm white.
Old 11-13-2023, 06:04 AM
touringmandan's Avatar
Contact Vintage LED's. They have GREAT LED headlights with optional period correct Bosch lenses.
We have installed more than 10 sets with VERY happy customers.
Old 11-20-2023, 06:39 PM
wdfifteen's Avatar
Yes, Jules Dinean has a whole system for most models of 356. I put his headlights in my 56 coupe and they are amazing. They’re a bit expensive and you can probably do some research and find something cheaper. His company is Arizona trading or something like that.
Old 11-23-2023, 09:00 AM
wdfifteen's Avatar
His website is vintagetraderaz.
Old 11-23-2023, 09:05 AM
Atypical Driver
VINCENZ0's Avatar
I recently installed the 6V LEDs from vintage trader and they made a huge difference. Driving at night is no big deal now.
I made this little video review in case its helpful, not a paid ad just a happy customer:
https://youtu.be/0oP4H0suw4g
Old 11-26-2023, 05:40 PM
techweenie's Avatar
Very helpful
Thanks!
1969 coupe hot rod
Old 11-28-2023, 02:18 PM
