turn signals
Hi,
How do you remove the turn signal lense to replace a bulb. does the entire assembly need to be romoved or is there an easier way? thanks
1965 356 c |
I've only had to replace bulbs in back , and the lens comes off, as does the chrome ring.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Thanks - I figured it out - they screw off - mine just had a bunch of sealer holding it down tight!
1965 356 c |
