Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
earlr85944's Avatar
help w\ carb synch adjustment solex PII 40
just got the gas to the engine and shes running pretty good.
I put a synchrometer on the carb throats and the right rear reads @6 the right front @9 the left front @9 and the left rear @8. How can I raise the right rear only? Its the Solex PII 40, or is there a carb adjustment and tuning procedure avail on the site?
RS
BTW will a valve adjust be first on the list before carb adj?
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 07-18-2006, 10:37 AM
Send a message via AIM to ronw
carb adjustments ALWAYS begins w/ valve adjustments then timing then carbs.
at this point if the front/back balance is still off then you will need to adjust by a) in the case of solid shafts twist the shafts every so slightly so that both butterflies are allowing the same amount of air to flow. b) if split shafts then they will need to be ajdusted indepentely.
Old 07-28-2006, 10:37 PM
earlr85944's Avatar
just adjusted the valves yesterday, now to the butterflies , thanks.
83 944....bye bye
Old 07-29-2006, 05:52 AM
