519 transmissions
Two questions
1- I have a 519 trans, and the stamped numbers on the bottom are 9961 H5, and 356 AGS. I assume the 9961 is the serial number. What are the other numbers, and is the origional gear set stamped someplace? 2- Is the ring and pinion from a 519 the same as a 644? |
