356 transmission rebuilder?
Can anyone recommend a 356 transmission rebuilder in the northeastern US? I have a '61 B that needs a ring & pinion set-up among other things.
gearhead
Stan Richardson at Gbox Performance in Boulder. He's been doing it for 30+ years and used to be the builder at Powerhaus II for the better part of a decade. He does excellent work and has quick turn around.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I can tell you who not to use or listen to and that is Dave Duerr of North River,NY also known as 356 Maven. He is a crook and a thief and has completly gone off the deep end.
56 356A Coupe 69 911S 69 912 (Roller) |
i'm just a cook
you might give bill mitchell a call at black forest in camden ny. 315 245 0555.
Don't forget to update to a 12 bolt diff carrier
I have had 2 done by Vic Skirmants. He is experienced, quick turn around and an expert. It is worth shipping the transmission to Michigan and get it done right. Good luck, Jim
http://willswerks.com
In northern Virginia did ours. Very reasonable and shipping is easy. |
Commerical Pilot
NOeast Trans rebuilder
Gary Fairbanks in Conn 203-866-2466
