Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Commerical Pilot
GLASFIBRE's Avatar
raer axle remove
Need some help...How does the rear axle assemblies come apart from the gearbox?
Old 07-15-2010, 11:04 AM
356RS's Avatar
The axle tubes can be removed from the transmission side cover after removing the axle boot steel side cover. Then the axles along with the ring gear & differential can be removed from the left side of the transmission after the left side cover is removed. You will need a plastic/rubber hammer to drive the complete assembly out from the right axle side.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2010, 09:49 AM
