DaytimeNightlife
Oil leak on freshly resealed motor
I just got my car on the road after 4 years of work restoring it. It runs/drives absolutely perfect, but is leaking oil and making me crazy. I think it's the flywheel seal. I wanted to get some insight from forum members so I hopefully will only have to drop the motor once to get it straight. The motor has new seals all around. I have read how people need to replace the flywheel seal upwards of 4 times before it stops.
- At idle it doesn't leak. I can run it for 20 minutes and nothing. Once I shut it down it will leak. - It usually will leak when I get the RPM's up. If I keep them down I usually don't get much of anything. - Visual inspection leads me to believe it's the flywheel seal. I have no drips anywhere, but where the trans/engine casing meet. I was just in Europe for 2 weeks and when I came home there were 3 drips hanging from the case and a nice spot on the cardboard I left on the floor. - I checked the top side of the motor and it seems dry and tight. All the culprits up top seem to be fine. How come it doesn't just always leak when running? I am so confused by this one. |
Hi Rudy
do you remember what flywheel seal did you use?If it is anything else then Elring they will leak. Also can you take a picture of the spot where do you see the oil leak? Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
76 911S Targa
Breather for the airbox? Maybe some oil blowing into the airbox and then dripping from the vent tube? It would be at the same place, approximately, as the main oil seal. Look inside the airbox for any oil to confirm. This would fit with hard driving if the oil expands enough to bypass to the airbox.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
DaytimeNightlife
I got my hand in there and confirmed the breather tube is connected. It seems dry. I will check the airbox, but I haven't experienced the engine smoking, EXCEPT when I drove uphill. I figured the oil was dripping onto the exhaust at this point. I really don't know though. I will go take a picture of the drip. I used this flywheel seal:
from my 35 year experience ..i stopped using Victor or any other makers of these seals.Only Elring since the 1980`s
Ivan this one has to be ... ![]() same goes for the front pulley seal
DaytimeNightlife
Here is the leak:
![]() I just drove it and it was leaking when I parked it. You think it's the flywheel seal? |
hi..yup your flywheel seal ,since all on top is well...but double check with a flash light and mirror..
Ivan
DaytimeNightlife
Can't believe I have to drop the motor again. I'm just glad it's running so good. It'll be nice to get this behind me. I will be reporting back with my results and some photos. I also was reading not to put it back in the same spot the previous one was installed? Is this correct? |
yes that is correct ..remember the position (before removing) and after cleaning the crank put it a little deeper 1-2 mm is enough
Ivan
Because of the amount of labor involved, I would buy or borrow a seal installation tool to make certain the seal gets installed correctly. Also, when you get the old seal out, check the crankshaft to see if there is a wear ring. If so, try to insert the new seal so that it wears on a different spot. A tiny bit of wear can make a huge difference. Also, best do the work now before the oil gets onto the clutch friction surface!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
+1 with Fred...also take a picture of the seal when you remove the engine so we can see it
Ivan
DaytimeNightlife
Thanks for the support and help guys. I really appreciate it. I will definitely be taking photos. I was already thinking about the tool. I think it's a no brainer. Anyone local to the SF bay area that has one?
The clutch has been on my mind the whole time. Should I not drive it until I get this fixed? I sometimes can't help myself when it's nice out. I can probably get the time this weekend to drop it and get it done. |
hi ,i have some friends in LA but that is too far for ya..I think in your case the spring fell off on installation because is leaking while you are at stop.
The tool is cool to have ,for me i have been using modified plastic hammer plus another hammer since the 1980`s again oldtimer teacher showed me ... on installation (if you do find the tool) lubricate the seal inside and gently tap evenly on all round corners.... Ivan Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 06-18-2018 at 11:54 AM.. |
Checked out
Having some special tool to install the flywheel seal is ok, but it really isn't necessary.
I don't think most pro shops use any special tool. The big issue, as said above, is not all 911 flywheel seals are created equal. I went through this exact same issue a while ago when I replaced my seal. You have to have the right one, or you have a good chance of a leak. Sucks! |
There is an oil galley plug in the end of the crank that I have seen leak in a few 3.6 motors.
Mark Kinninger
79 930 405 rwhp,84 911 track car |
Still here
BTW that pic with perfectly symmetrical pair of oil droplets is neat. You must have cleaned the case before every drive ! |
Checked out
I don't recall the brand that I ended up getting that worked, but it was a "two tone" colored one like posted above.
The single color one that I initially used leaked immediately. Get whatever tool you want, but focus on getting the correct seal first! With the wrong seal, it's going to leak no matter how you install it. |
DaytimeNightlife
LOL you know it! Clean it like a crazy man. I did all that work I want to keep it clean! The drops were dripping and I waited for the one to fall and even out before I snapped the shot!
DaytimeNightlife
New seal has arrived. My dad isn't around. Anyone want to come hand me tools and yell at me?
no but my son will come help , he says I taught him well at how to hold a flashlight and get yelled at ..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
