Emblem mounting
The carrera emblem on my 86 targa came off. What do I use to reattach it?
kb mercedes GLK350 2009 boxster s 86 targa |
Member 911 Anonymous
They are attached by two speed nut, I recall 7MM (8MM maybe). Lift hood and you will see two holes for access. Do not over torque it or use 3M Weather Sealant to help keep those fasteners on
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Brew Master
Emblem adhesive. It's a glue on emblem. You could take the old two sided adhesive off and replace if you want. I just bought another rear emblem and put it on. Just make sure you clean the surface well before installing.
Who makes the emblem adhesive.?
Brew Master
