Broken differential?
My 915 transmission (no LSD) started making a clunking noise today. I've checked the short shafts and don't think there's an issue there....
However, with the rear jacked up, I tried turning one rear wheel and noticed the other side not turning in the opposite direction. Shouldn't it?
Can you help me understand what's probably wrong? Can you identify what parts based on my brief description?
thanks,
Old 09-06-2018, 10:45 PM
Send a message via Skype™ to Porboynz
Usually that does happen when both wheels are hanging clear, but if in neutral then not always if there is a bit of brake bind. If its in gear and you prevent one wheel from turning and you can turn the other you have issues.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 09-06-2018, 10:53 PM
Okay - I'll jack one side up (in gear) tomorrow AM and see if I can turn a wheel. If I can, what kind of issues internally?
Don't think I had sufficient brake bind to restrict rotation on the initial test I described above.
thanks,
Old 09-06-2018, 11:11 PM
CV joints clunk. pop. snap...
206 637 4071
Old 09-07-2018, 11:55 AM
gearhead
That's my thinking on it.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-07-2018, 12:06 PM
thank you John & Matt.... that was my first guess and that's what I went for. But when I lifted the rear end and the opposite wheel didn't counter rotate, I thought it might be internal.
I can now try and do some simple turns and see if it occurs in one direction vs. the other.
I also lifted one side at a time and while in gear, couldn't get either wheel to rotate, so I guess I passed whatever test that was for...
Can you guess why my turning one wheel and the other not counter rotating might be due to? Or, that was your point - the CV isn't linking to the trans?
thanks,
Old 09-07-2018, 12:13 PM
gtc gtc is offline
abides.
gtc's Avatar
Make sure the axles are not spinning in the CVs (due to bad splines at the end of the shaft).
Graham
1984 Carrera Targa
Old 09-07-2018, 01:28 PM
thank you.
aside: one of the first problems I ever had with a car was due to a bad spline. Year - 1964 on a 1957 Austin Healey... right rear wire wheel.... "you mean you need to put grease on that?"
thanks
Old 09-07-2018, 05:09 PM
… axles not spinning in the CVs - at least for turning wheels by hand.
So, I'm hoping someone will help answer the question - with the rear end jacked up, and assuming the CV joints are okay, why doesn't the opposite wheel counter-rotate when turning one side? (this isn't a limited slip)
Anybody experienced this - and what caused it?
thanks again,
Old 09-08-2018, 09:41 PM
