86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Light.
Originally Posted by rokemester View Post
I have a message into Carmagic to see if they have a LED tube bulb that will hold up to the engine compartment heat.
Is that what you used?
Gery
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-13-2018, 08:55 AM
polizei's Avatar
Originally Posted by wjdunham View Post
I had this same problem on my '85 and took me a while to figure it out. I replaced my rusty old light with a new one and wound up blowing the fuse when I turned the lights on. There was a short from the 12V wire to ground that I could measure with a meter. It went away after I pulled the light and let it hang in the air. After trying all sorts of tape and shielding, I finally tried rotating it 180 degrees and that cured the problem. Evidently these can only be installed one way due to the way the ground return is wired up. Hope that helps.
Bill
Swapping wires did the trick. Thx so much!
Old 10-13-2018, 10:13 AM
rokemester's Avatar
Look for 41mm feston at this link from Engelbert at Carmagic
They can also be ordered individual from the LED bulb page https://carmagic.us/led-bulbs.html
Old 10-13-2018, 03:20 PM
That's fond- just deglaze
Gery
Hi Gerry- Found it! It's the Philips 128026000KB1 43mm festoon Bright White Interior Vision LED light. It has a cover over the bulb- works great.
Old 10-13-2018, 06:05 PM
Banned but not out, yet..
RSBob's Avatar
I have 4 festoon LED lights not being used. They are a super bright white light, ideal for the engine compartment or if you want daylight inside your cabin. I put one in my 914 backpad light and it more than does it job. If anyone wants one for free, PM me with address and I’ll Mail you one. U.S.only.
Old 10-14-2018, 06:20 AM
Bulb.
Thanks, one is on the way.
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-14-2018, 06:55 AM
Light.
Just installed one today.
What a great improvement.
Gerry
1986 911 Targa.
Only in L.A.:
Old 10-17-2018, 07:47 PM
UnRegistered User
billybek's Avatar
. This is a fine piece of German engineering. Really is more at home in my 66 VW than the Targa. Still no joy by the way.
The same light resided in my 1974 VW Thing's glove box.
Bill K.
Old 10-18-2018, 03:35 AM
Reviving and old thread since its the best for this questions.
Does anyone know the part number or size/description for the screws and mounting clips to attach the light fixture?
I looked on the PET but could not find them.
thanks
Old 04-12-2023, 12:39 PM
PCA Member since 1988
Just eyeballing, they look like M5. Go to Ace Hardware or similar and buy a couple of appropriate length in stainless steel and see if they thread in. If not, try the next size down, M4. In fact, they will let you take one out to your car and see if it fits., then buy several extras. License plate lights are the same size, IIRC.
And thanks for reminding me. I have a 1973, which did not come with these lights, but I want to buy two LED12v lights and screw them in on each side of the lid. Better illumination that way. I'll just wire to the license plate circuit (also on the deck lid in 1973)
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-12-2023, 03:18 PM
thisisgoodnews's Avatar
Here are a few pics to show insulator fab and wire orientation.
Been going after my engine compqrtment light as well, and thought it is a nice idea to put the insulator there. But then, after a second thought, light housing will still be connected to body through the mounting scews, so there little point to it.
Or am I getting something wrong?
'86 3.2 Carrera
Old 09-19-2023, 03:47 AM
