New Engine Compartment Light not working and wiring is HOT
Hi everyone,
In the 11 years I've owned my '87 Carrera, the engine compartment light has never worked. I tried replacing the bulb, and it still didn't work. I've now replaced the entire light assembly (the old one was not looking good). When I turn on the parking lights, the wiring to the engine compartment light immediately gets HOT. I immediately turned the lights off and the wire cooled. Before pulling the fuse (4th from the front of the car - controls driver side parking lights and engine compartment light), I noticed that both front parking lights worked, but the rear driver side light did not. When I pulled the fuse, the front drivers side stopped working and the engine compartment light wiring stayed cool. I noticed that the fuse was 25 Amp! Bentley calls for a 5 Amp. Yikes... Any thoughts on what may be the issue? Thanks!
Andy - 1987 911 Carrera Coupe Last edited by polizei; 10-11-2018 at 07:12 PM.. |
I’ll be watching this thread. My engine light used to work after I cleaned up all the contacts. Now it’s not working and hasn’t for a while.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
ROW '78 911 Targa
I suspect your wiring to the light housing is shorting to ground. Likely at the housing.
Fairly common.
Thanks. I checked the wiring, and it looks like the positive & ground cables are secured well to the housing. I don't see any tears in the wire sleeves. Any suggestions on what to troubleshoot next?
Andy - 1987 911 Carrera Coupe |
I fixed my fuse issue, but my fix may not apply. There are several threads here like this one...
http://forums.pelicanparts.com/porsche-911-technical-forum/203865-fuse-drivers-side-running-lights-keeps-popping.html
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
ROW '78 911 Targa
Did you test with a meter? One contact on lamp is power, should be no path to ground from it.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 10-12-2018 at 07:24 AM.. |
+1....power shorted to ground.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I had this same problem on my '85 and took me a while to figure it out. I replaced my rusty old light with a new one and wound up blowing the fuse when I turned the lights on. There was a short from the 12V wire to ground that I could measure with a meter. It went away after I pulled the light and let it hang in the air. After trying all sorts of tape and shielding, I finally tried rotating it 180 degrees and that cured the problem. Evidently these can only be installed one way due to the way the ground return is wired up. Hope that helps.
Bill Last edited by wjdunham; 10-12-2018 at 08:42 AM.. |
That's fond- just deglaze
Hi Polizei- Agreeing with @wjdunham on position- here's a shot from the owners manual (note position) Also- I switched over (no pun intended) to an LED bulb as well- lower voltage, low heat.
...and with the LED bulb:
I had the same issue. You probably have the positive and negative reversed at the light housing like I did
Derrick |
WOW let the sun in baby! Nice upgrade.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
May we have the top secret p/n for the led bulb?
Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Light.
And, verify that the spacer between the housing and the deck lid is intact. The spacer serves as an insulator between the +12v and the chassis ground. Also, the parking lights must be on for the engine compartment light to work. Not sure about the requirement for the 25A fuse. I think the Bentley is correct. pm me as need. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-12-2018 at 01:28 PM.. |
I disconnected the engine bay light and cleaned up all the contacts with a Dremel. This is a fine piece of German engineering. Really is more at home in my 66 VW than the Targa. Still no joy by the way.
Gerry- I am searching for the Part Number for the LED replacement, (its been a few years since I made the switch)
Got the light to come on momentarily, but won’t turn on consistently. If anyone happens to have an exploded view of how the light housing is assembled to deck lid that would be great. I don’t have a spacer or washer that fits between the fixture and engine lid. I tried to turn the light on without the black dome housing on. The light wouldn’t turn on. It almost looks like the two housing retainer clips are contact points (I confirmed they have nothing to do with switch electrics! Although the black housing needs to snug down as tightly as possible) When I put the housing back on the light lit up briefly.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V Last edited by rokemester; 10-13-2018 at 08:09 AM.. |
A good night sleep often helps clear my mind and allows the information I’ve gathered the day before to settle in. In a previous comment here “verify that the spacer between the housing and the deck lid
is intact. The spacer serves as an insulator between the +12v and the chassis ground.” it was said that the housing needs to be insulated from the car body (the deck lid). Often times critical parts/washers are missing when we go to repair our cars. This was the case here. I fabricated a thin hard plastic gasket from a take away food container top. This led to the proper routing of the gray power wire and the brown ground wire to the light.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V Last edited by rokemester; 10-13-2018 at 08:16 AM.. |
Here are a few pics to show insulator fab and wire orientation.
![]() ![]() ![]() I learned that is important to have the wires enter between light housing and insulator and up through hole/slot in housing. This allows black dome cover to fit snug and allow complete movement for the cover switch. Mine is still finicky and I need to give it an extra push to get it to light. Just want to keep the original as I’m guessing the new ones aren’t as solid. ![]() ![]() Thanks for the great information from the forum members and the fellow 87 owner who started this thread. This one had been bugging me.
I have a message into Carmagic to see if they have a LED tube bulb that will hold up to the engine compartment heat.
Thread Tools | |
Rate This Thread | |
