Smoke coming from oil filler tube/oil filter area
As the title suggests, I have some smoke coming from around the oil filler tube and oil filter area. Nothing from below or out of the exhaust. Any suggestions on where I can start checking this would be appreciated.
https://youtu.be/MRs_KMLM8h0 https://youtu.be/5vfkJG5nvQw Last edited by brandonelliott; 06-27-2019 at 02:31 PM.. |
Looks like an engine oil leak from the lube system (filter, oil fled pipe, loose filler pipe hose, crack?, etc.). What do you see under the car? My guess - oil leaking from ? onto the heat exchanger (exhaust).
Still here
Overfill ?
I don't see any oil on the ground, and when under the car I don't see any smoke at all. It's only visible from above the engine. It definitely smells like oil burning, though, so it seems like that has to be it.
Not an overfill, I thought that could be it too, but measuring the oil it shows correct on the dipstick. |
how do you measure your oil level??Engine hot and on idle..correct or not:-)
Ivan teka \the filler cap of and see...sorry ==take the....correction
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 06-27-2019 at 03:15 PM.. |
Hadn't considered running the car with the cap off, will try that tonight. |
Red Line Service
It may be coming from the right heat exchanger. If the heater box is closed, the air from the heat exchanger is dumped under the car by the right axle. Smoke from there can come through the gap between the suspension crossmember, and the rear seat pan. Take a look further forward and see if the smoke is actually coming from the area of the RR upper shock mount, forward of the charcoal canister.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Still here
Did you figure this out ?
The vid appears to show smoke from the vicinity of the breather hose and "pulsing", meaning not just a static burning pool. The second vid shows oil staining around the filler pipe around there. |
I'm thinking that the oil tank cap gasket is broken or missing.
nothing gets hot enough on the oil tank to create smoke. oil on the exhaust makes that kind of smoke.
you need to look under the car for a nice big oil leak that makes that amount of smoke non stop. that is if keeps smokes like that continuously. when first reading your post I was thinking a small amount that could possible be coming from the engine and blow by making its way back into the oil tank and out, perhaps the oil cap as someone suggested or maybe from a hose connections on the tank. buts that's a lot of smoke.
Car needs to be running when you check oil. if you're seeing proper oil levels with the engine off (suggested by your comment above that you hadn't considered running the car with the [oil] cap off"), you've likely overfilled your oil. |
Take the oil cap off and see if pressurized air / smoke is coming out. if it is, no bueno (bad ring for rings).
What year 911? Chris |
Car needs to be hot, level and at idle to check oil level with the dip stick.
Chris |
Ring not seated or wear out Blow by engine Or cap is leaking on exaust run it with out oil cap to see if it come from oil tank annd check if breather hose is not inverted.
