993tt to GT2 clone
Bought the best candidate for a GT2 clone ever. (pretty much my favorite car) Car is a 1997 993turbo in artic silver. Has been a customer car for 10+ years and driven only on Sundays and maybe a few Saturdays also. Spent time doing DE's and was built back when these cars were worth maybe $50k. Original doors and fenders with good gaps and a whole bunch of rock chips up front. Converted to two wheel drive when I first got it back in September. Got rid of 80lbs weight in one day. From there it went to metal guy to get sunroof welded up. He cuts the opening larger by approx. 1" so there is no rolled lip anymore. From there he rolls a flat piece of sheet to get the right curve and tig welds it in place. Came out beautiful and needing almost no filler. More pics to come. Car is almost ready for paint. Mark Kinningerhttp://forums.pelicanparts.com/uploa...1544329715.JPG
http://forums.pelicanparts.com/uploa...1544329715.JPG |
very cool! did the GT2 of the era have any of the bits from the widebody NA RSR's race cars suspension and chassis wise?
Sure would like to get rid of the sunroof in my SC. . . Lame excuse to post and subscribe to this thread, I know.
The street Gt2 suspension was more closely related to the 993RS |
Can't wait to see how this turns out. Another great project Mark.
Very cool!! Can't wait to see this project
Hey @skidmark,
Is this one of your engine builds? Would have been in 2007 according to the receipts: https://bringatrailer.com/listing/1982-porsche-911sc-35/ Thanks, Charles |
Did Porsche not have rear fender vents on that model of Turbo? Will you be adding them?
http://forums.pelicanparts.com/uploa...1544555715.jpg http://forums.pelicanparts.com/uploa...1544555715.jpg http://forums.pelicanparts.com/uploa...1544555715.jpg http://forums.pelicanparts.com/uploa...1544555715.jpg |
When you are done are you anticipating a greater value or is that not an issue? I really don’t know how values are influenced for this kind of change.
Mine with flairs. I SCOURED the internet looking for pics of how factory steel fenders got cut with no luck. Fortunately I have a customer with an original GT2 street car and he was totally cool about bringing his car by so I could rack it and take lots of pictures. His were cut back so much I decided to cut mine after they are painted so they can sand and buff the surface without it distorting like a wet noodle. http://forums.pelicanparts.com/uploa...1544578533.JPG
http://forums.pelicanparts.com/uploa...1544578533.JPG |
Mark Kinninger |
Should also mention that sorry to say the red wheels will be going away after the body shop is done painting car. Leaning towards BBS E88 wheels with retro gold centers. 12's in back and 9's in front with LOTS OF LIP! (only a little stretch though)
If one of you has to have them I could be talked out of them. Kinesis 8 and 11" by 18" and 80% r6 hoosiers bought this year. |
Body shop is prepping car and could be painted within two weeks. Motor has less than 50k miles but I am rebuilding top-end anyways. Exhaust valve guides were worn so they were replaced and full valve job. I ported intake side of heads and also am running a set of 1995 993 n/a cams. With the 1.bar boost remap I am hoping for 550hp. http://forums.pelicanparts.com/uploa...1546300768.JPG
I did a RUF 600 hp kit on a customer TT years ago and they sent new n/a 993 cams in the kit. My cam grinder said the n/a cams are bigger however I should double check that since you bring it up. The next step up is 3.8rs cams but they get a bit too lumpy at idle
http://forums.pelicanparts.com/uploa...1546305168.jpg |
Back from body shop just a few days ago. I pulled the doors before paint so they could shoot the jambs at the same time as rest of car with no masking lines. Came out amazing. Spent my s Saturday cutting the fenders and hanging flairs.
CAUTION! The next pictures below may be disturbing to 993 owners!http://forums.pelicanparts.com/uploa...1547340674.JPG http://forums.pelicanparts.com/uploa...1547340760.JPGhttp://forums.pelicanparts.com/uploa...1547340833.JPG |
500whp will be easy on the current setup with the right turbos. 60mm-67mm seems to be the sweet spot for compressors. Personally I like the GTX2863 in this application. If dedicated track car step up turbine to GT30 so it will run cooler. The real limit will be CHT’s. E85 is a game changer for that! Good luck! Love the build!!! |
Looking good Mark!
Black would’ve been amazing but silver is nice too, sub’d
http://forums.pelicanparts.com/uploa...1547416604.jpg |
Great project.
I have a factory Porsche Motorsports 993 GT2 3.8 EVO engine, rear deck lid, wheels, factory quarters and other parts if you need any :) http://forums.pelicanparts.com/uploa...1548265096.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg http://forums.pelicanparts.com/uploa...1548264639.jpg |
Is it normal for these to be single plug heads?
Sent from my Nokia 7.1 using Tapatalk |
http://forums.pelicanparts.com/uploa...1548279623.jpg http://forums.pelicanparts.com/uploa...1548279623.jpg http://forums.pelicanparts.com/uploa...1548279623.jpg http://forums.pelicanparts.com/uploa...1548279623.jpg |
The heads shown in post 18 are single plug, appear to be from the original 993tt?
Once tuners got ahold of them they switched to the twin plug setups |
Car should be running this weekend. Then I drag it home to finish assembly with Daytona 24hr on to keep me inspired.http://forums.pelicanparts.com/uploa...1548299106.JPG
http://forums.pelicanparts.com/uploa...1548299131.JPG |
Driver door assembled. My front splitter should show next week along with brake cooling scoops sporting projector lights.http://forums.pelicanparts.com/uploa...1548546622.JPG
Front splitters still at paint so I rolled out for some butt shots. Forgeline came through with very nice wheels. 9 and 12 by 18". I almost ordered BBS E88 but I like their take on version of that wheel. Centers powdercoated semi-transparent so you can see the machine marks.http://forums.pelicanparts.com/uploa...1549819554.JPG
http://forums.pelicanparts.com/uploa...1549819647.JPG |
It's a good thing you're near Gillespie Field. The take off roll won't be that long. Seriously, that things going to fly. . .
Looking good!! What the plan for the interior?
9" and 11". http://forums.pelicanparts.com/uploa...1549997106.jpg http://forums.pelicanparts.com/uploa...1549997106.JPG |
Awesome build, Mark!
