Don
High Beams Cut Out
On my new-to-me 1988 Carrera, when I pull back on the lever to flash, low beams stay on. When I push the lever forward the lights go completely out and the driving lights stay on. All fuses are good.
I've searched the forum and I've seen some threads about the switch, but not sure the symptoms above indicate the switch. Ideas appreciated. |
Don
I'll give it a shot. Thank you!
Don
Replacing the switch did the trick. Thank you!
...and I've spent far too long trying to get these pictures to post right side up. ![]()
You should also install a headlight relay kit unless the 88 year has them already.
