Finding electical terminal housings
It seems my electrical connectors are becoming brittle due to age and heat I can find the female connectors (022 906 231 and 022906 233 - B) but I am unable to find the male side of the connector? here in Australia we are a bit backward in finding parts(or maybe its just me) so I have to go overseas - can anyone help with a part number that I can search?
Shorty 1988 Carrera Cab |
Those male connectors are on the sensor side and are part of them, so when you replace the sensors you get new male connectors.
Can't see much on your pic but it appears that both flywheel sensors have their sheath gone. The plastic flange around the male spades is gone too. Time to change both of them. Get two Bosch 0 261 210 002, they fit perfectly and are cheaper.
Gilles RoW 88 Carrera coupé |
I know some of the BMW plugs are the same.
https://www.*******.com/products/bmw-plug-housing-12521706096 OE Numbers 12521732596, 83300493003 |
go to digikey (dot) com and look for
part number 1-962581-2 for the 3 pin for the 2 pin I think you can get away with 106462-1 with some minimal modification. on the factory 2 pin connector the alignment ridge is offset to one side. this connector has the ridge on the center line. I believe this consists of 2 small parallel ridges on this connector and you may need to file one of these ridges off or worst case file them both down, to get the plug to fully seat. this may dictate that you pay attention to ensure you plug the connector together with the correct polarity each time it is unplugged, to you may want to add an alignment mark with paint of the like as a reference,. |
Connectors
Try this link....comes with grommets and terminals....just specify wire insulation size and wire size
Corsa Technic..... ![]() Last edited by rsscotty; 05-23-2025 at 12:42 PM.. |
