Dept store Quartermaster
lendaddy's Avatar
exhaust studs, special tool?
Is there a special tool to install/remove the exhaust studs? I have a picture in my mind of a socket looking deal with cam locks inside. Does this exist?
Cornpoppin' Pony Soldier
Old 03-18-2003, 06:02 AM
most just double nut
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-18-2003, 06:25 AM
Yep, this tool exists. Check out this link:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=5237
Regards,
Boris
1987 Carrera
Old 03-18-2003, 06:44 AM
lendaddy's Avatar
Excellent, Thanks. I wonder if these also work for installing or are they one way only? Site calls the extractors.
Old 03-18-2003, 06:52 AM
VincentVega's Avatar
The stud extractors I have used all damage the threads at least a little, even the snap-on version. Just a heads up.
Old 03-18-2003, 07:07 AM
exhaust studs generally don't come out, regardless of what you do. they just break off. maybe one in 20 comes out. the ones toward the outside are too close to the cam tower to get anything on them anyways.
206 637 4071
Old 03-18-2003, 07:52 AM
lendaddy's Avatar
John,
I took my shorty headers off last night and about a third of the studs came out easily with the nut. Granted I have been hitting them with penetrating fluid for months(yes I was paranoid and the motor was just sitting there anyway, so). The studs look pretty nasty, are you saying I am going to have trouble if I try to replace them all? Should I reuse the ones that are in there even though they look a little rough( surface rust etc..)
Old 03-18-2003, 08:01 AM
Seldom Seen Member
Burnin' oil's Avatar
The best tool is a machine shop. I replaced all of my exhaust studs a few months ago. Three or four came out easily, giving me a false sense of hope. I broke a couple studs off, then broke off a screw extractor inside a stud. Then I called the shop. Good Luck.
Why do things that happen to white trash always happen to me?
Got nachos?
Old 03-18-2003, 09:13 AM
once in a while you get lucky and several will come out with the nut, but it doesn't happen often. if the stud is useable, i think you should leave well enough alone.
206 637 4071
Old 03-18-2003, 09:44 AM
lendaddy's Avatar
Fair enough, I will take your advice and let sleeping dogs lie. Thanks again.
Joel
Old 03-18-2003, 09:52 AM
