911/912E breaks
Hi All,
I am having trouble removing the rear brake caliper lower attachment bolt from a 1976 912E (should be the same as a 911, same year). Very tight quarters. Is this a case for Porsche special tool #???. Any ideas/suggestions? DJ Last edited by DJ Connolly; 04-20-2019 at 04:09 PM.. Reason: Spelling |
I think you meant " Brakes "
Thank you Sir (or Madam), engineers seldom burden themselves with the complexities of the printed English language.
That being said, any ideas on getting that lower bolt out?
This has a lot of info - http://forums.pelicanparts.com/porsche-911-technical-forum/901020-removing-rear-brake-caliper-what-tool-works-best-bottom-19mm-bolt.html
Good luck! |
911/912E Brakes
Darrin,
Thank you for the post, it was exactly what I was looking for. DJ |
