Asking for Advise. I'm rebuilding a 3.2. Should I do 3.4/5 twin plug, etc.
I am in process to find a place to fix my engine, transmission, and clutch. I would like to get advise from two perspective, the best option to buy the parts and the advise on the Engine.
I don't have the tools, the knowledge and the time to do it. Therefore I am going to take my car a local shop here in Dallas. From the perspective of buying the parts, I was thinking on creating a list for the full project (clutch, pistons, seals, hoses, etc) and get quotes from 2-3 places. I don't think there is another way to get a better price. The main question is on the Engine, I am not sure if I should go stock or it is the time to do few upgrades. - after reading several threads, I got the idea that the best performance upgrade -I will get it in the headers and muffler. - Other guys are also suggesting to get 964 cams and upgrade to 3.4 or 3.5 (I will not bore the case) - And finally some gurus are talking about twin plugs. (here is where I have read a lot, people talking about Andian, using two 964 coils, and big thread talking about using a 993 single unit with inverter). - I am looking a reliable car for the street (no track). - I think that if I am going to buy cylinders and piston, go the path for 3.4 and upgrade the cams using 964's. -Twin plug.- it will allow to have a higher compression, but I think is very expensive and it doesn't give me a lot of HP. and it affects the reliability of the car. -At some point I was thinking on e85. If I am replacing the fuel lines, fuel pump and injectors - take the effort on switching it into e85. This is not even into consideration any more, I read that there is no significant gain of power (4%) and it is more complicate when the car is idle. - Something that I think will consider is upgrading the oil pump for a 964. - Valve guides and ARP struts. - Should I balance the clutch and crankshaft? - Any suggestions on the upgrades are welcome. Thanks |
What is your budget?
Get that clear and the rest is easy. |
I could not agree more, your budget will dictate.
I will be balancing everything ARP studs ARP rod bolts increase my bore somehow (budget will dictate) 964 oil pump 996 cams David Last edited by Harpo; 07-06-2019 at 09:21 AM.. Reason: typo |
I know my engine is different but the logic might be the same
My cylinders were good. New pistons are not all that expensive compared to some other bits, so on my 3.0 I went higher compression and twin plug. I initially wanted to go bigger, but that meant cylinders, which in my case upped the price by just too much. plus, I could see the coolness of a twin pug setup. I wouldn't be able to see the parts used for bigger bore ;-)
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
The 9 Store
I would talk to the shop you plan to have build your engine and see if they are ok with you providing the replacement parts. Most shops are not but if they are, won't generally provide a warranty.
All used parts sold as is. |
^this! Also, strongly recommend finding/working with a shop that has experience with 911 engine rebuilds and 3.4/3.5l conversions -- let the shop leverage its experience/knowhow and (at a minimum), see what it would recommend parts/specs-wise as your first step here.
Good morning Guys, Mepstein and Darrin - yes, definitely I will review with the shop. But at least you need to have an idea of what are you asking.
If you are going to fix the engine and transmission, what are the upgrades that will make sense and will not be a big budget increase. For example, I like Harpo response: ARP studs ARP rod bolts 996 oil pump 996 cams --- I am not sure about boring Harpo thanks, I was reading only about upgrading to 964 oil pump and cams, but now I will also review with the shop considering the 996. Mepstein, the parts - I will talk with the shop. But I will get three quotes, and if he can be close to the quotes - good we are in business. Peter, the budget, I have some freedom. I am not planning on selling the car, but you always have to consider that option (I had a friend who got cancer and sold his Thunderbird - sad story. Sometimes the good things are there to help us on the bad things). In addition, I only drive weekends and around town. Therefore, I don't want to have a crazy upgrade and narrowing my market - if tomorrow I have to sell it. (Unfortunately there is a good budget, because I was saving to buy a Porsche Carrera T. I went to the dealership back in January and they told me: -" We can take your downpayment and give you a nice 992 in Jan 2020". I said, Thank you and walk away... after many years of savings, the dream ended) You might ask, why were you considering e85? I read that is cooler fuel compare with 93, and supports higher compression. unfortunately there are a lot of drawbacks and as result I am not any longer considering it (in addition to narrowing my market). Thanks for the advise, I really appreciate! Happy Independence Day! |
The 9 Store
I'd be weary of any shop that lets the customer pick out the parts and/or supply them. You are admittedly new to this and yet you are trying to pick out the parts for a (hopefully) experienced engine builder to build into an engine. Just like a customer who wants to pick out the brand of paint to paint their car, the wrong person is making the decisions. Every engine builder will have parts and systems they are comfortable and confident with. Throwing a list of parts at a builder without the understanding behind them is letting the inmates run the asylum. 2nd, a shop makes money on parts and labor. If you reduce their normal profit margin, why would they do your build over one that is paying normal shop rates. It wouldn't be because they are busy or good.
If you trust the shop you have in mind, a better approach is to discuss what you want from the rebuild and what you need to budget to get you there. Then let the shop put together a plan that works for both of you. Good luck with the build and happy 4th.
The 9 Store
A 930 or GT3 pump will work but usually isn't needed, even for a hot street 3.2
All used parts sold as is. Last edited by mepstein; 07-04-2019 at 12:15 PM.. |
+ 1 on Mep's parts program. When supplying parts to a builder where no prior relationship exists, if something's not right along the way or worse, in the end, you---not the builder nor the parts supplier---will most likely be paying for corrections.
Thinking of my own 3.2 > 3.4 build, I chose to define "performance" not as adding HP but as building in endurance/durability. That thinking focused on reducing reciprocating weights, balancing motive parts well beyond Porsche specs, minimizing friction, and refining lubrication. While these can serve +HP... the thinking behind it all cuts a different path. Research led to... ![]() Mahle (among others) will allow you to custom design pistons. My goal = cut off as much fat as possible without sacrificing structural integrity. Mahle will help make design decisions based on owner objectives. Or, supply them a CAD file. Mahle makes one-off prototypes for product inspection prior final production. I found them very helpful. ![]() Ultra strong low weight pins---I forgot metal spec/source. You can find by Googling. ![]() LN Engineering does Nikasil cylinders... and they collaborate with Mahle. ![]() Reducing friction between motive surfaces... ![]() Refining position of rod bore in piston to ease stress on piston, rings and cylinder. Weight reduction is also a factor in rod selection. Very exacting tolerances in all assemblies is called for. Doing this yourself, you can invest as much time as you want to achieve a very high degree of precision. When working with a shop, achieving beyond "standard" precision---provided shop is capable---gets expensive. Force feed oiling to pins. This is Carillo brand. Other makers do same. Was debate on whether this was worth doing provided a case having squirters... in which case squirters could be sized up...then forget drilling rods. (I liked idea of forcing.) Ultimately there was a noticeable weight reduction per piston assembly that when X's 6... the figure varies depending on assembled components---regardless, the figure is consequential compared to stock parts. ![]() Credit: I will find who did this and edit later. Cross-drilling crank to aide lubrication---a proposed requirement along with larger oil pump (were one to force feed pins.) Parcel to achieving silky smooth running engine is zeroing out alignment of crank's journals. All bores should be treated same. Boat tailing case to ease airflow inside case. Knife-edging crank weights. ... This barely scratches surface of what can be done when thinking of engineering a build for endurance. Of course parts & work here---similar to adding HP---add dollars to build. While I did not project ROI, and based on not running pizz out of an endurance build, my thinking = eventually endurance-build dollars do have a return (provided car is kept long term by owner.) .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
My advice is speak to William Knight, for a no BS scenario that delivers results
http://forums.pelicanparts.com/porsche-911-technical-forum/129421-william-knight-superhero.html With William’s advice mine came through pretty well: https://forums.pelicanparts.com/911-engine-rebuilding-forum/907542-gt3-crank-3-2-3-4-a.html |
Thanks Discseven, I will keep in mind those brands.
In terms of Clutch, is there a particular brand that I should review? And guys, About the parts, definitely I will give the shop the freedom to buy them from their distributor. But if the price for the part is very high - I will search for another shop. Getting three quotes is the only way that I think I will be abel to see if the price for parts is acceptable. |
Sorry guys The 996 oil pump reference was a typo. I meant to say 964
David |
A 996 oil pump absolutely fits in a 3.X case - a 996GT3 oil pump that is. Needs case clearancing, but fits.
What does a 964 or 996gt3 pump gain one in this setting (3.4 l displacement bump with motronic?) haven’t thought of Carrera oil pump as weak link in same way as rod bolts or head studs ...
The 9 Store
All used parts sold as is. Last edited by mepstein; 07-06-2019 at 03:51 PM.. |
964 gives you more volume and reliability and is recognized as one of the better more durable of the production pumps. |
thanks catorce -- so, in this type of build, unless the 3.2/carrera oil pump needs to be replaced (failed or worn out), no compelling reason to upgrade.
What ecu is running all this? If aftermarket, I’d still consider a flex fuel tune for e85, as that’s an easy few hp picked up whenever you feel like popping some in.
And would make use of twin plug stuff easier if you wanted to implement that |
Hi mepstein, yes the budget is considering a good scenario. And until they inspect inside - they will be able to give me a more precise quote. and guys if I was asking this question, it is because not easy to invest 20-30K on a car. But I got a good idea. Thanks |
