7783911's Avatar
great work
would like to know the part number of those vw pulls if you could post or a link?
Old 03-22-2020, 04:24 AM
Awesome job. What sis you use as board to build your door panels. I may embark on building my own as well.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-22-2020, 06:38 AM
Matthew_VA's Avatar
WOW! This is looking amazing! Great job and look forward to seeing it finished.
Old 03-22-2020, 09:56 AM
SWS911's Avatar
Why did you choose to French seam the ends, looks cool btw, on the one pc knee pad?
Old 03-22-2020, 10:38 AM
Just found this thread: superb vision and execution. In the general scheme of what we all do: Mechanical? Check. Body and Paint? Check. Interior and Upholstery? Not so much. Jim Tweet is another guy who's discovered the sewing machine and turned out great work that can really transform the feel of a car, as did Queenie from New Orleans (we haven't heard from her recently, hope she's OK?)
I'm renovating a 924S and would like to get rid of the rear seats in a way which doesn't look terrible, so this thread, while about a different era/style is totally apropos.
Anything you can show with your technique, materials would be appreciated. Such as sewing your carpet bindings, building the cabinet/structure of your rear seat delete, etc.
Thanks much, John
Old 03-22-2020, 11:35 AM
rangrbob
rangrbob's Avatar
Originally Posted by 7783911 View Post
great work
Here is one from J-Bugs: https://www.jbugs.com/product/16-1612.html
I bought mine from NuVintage, a VW parts shop in Arvada CO. They were made by Wolfsburg West. 1960-1967 Bug armrest
If you have a salvage yard near you that has old VWs, it may be worth a shot to see if you can find a good used pair.
Old 03-22-2020, 08:08 PM
rangrbob
rangrbob's Avatar
It was more the fact that I just wanted to see if I could actually sew them. I thought they turned out pretty good for a first try, so I went with it. I think I could have got away with softening the vinyl with a heat gun to stretch it over the ends, but I did not have enough to do it in one piece. I've been using a Singer 4452-heavy-duty-sewing-machine that I bought at a local Joann Fabric store. It has been working out fine, but I really would like to find a Consew or Juki machine if I continue to do my own upholstery.
Old 03-22-2020, 08:27 PM
rangrbob
rangrbob's Avatar
Chris, (aka Duc Hunter)
I used roughly 3/32" (not quite 1/8") plywood that I got free at a local wood supply shop. They use it to cover their premium veneer plywood sheets to keep them from getting damaged. It works really well. Although, If I were to do it over, I'd probably use 3/32 ABS.
Old 03-22-2020, 08:37 PM
SWS911's Avatar
plywood vs. ABS
I used 3/32 plywood that I got free at a local wood supply shop. They use it to cover their premium veneer plywood sheets to keep them from getting damaged. It works really well. Although, If I were to do it over, I'd probably use 3/32 ABS.
I'm considering using one or the other in my Vanagon Wesfalia. What were the pitfalls of the plywood and what would be the advantages to using ABS. I've heard that not much "sticks" to ABS.
Old 03-22-2020, 08:45 PM
7783911's Avatar
Thanks for the link
can you tell me the spacing of the mounting holes for the armrests..i assume screw underneith and would use a jacknut in the door?
Old 03-23-2020, 06:14 AM
rw7810's Avatar
So how did you attach the rear seat delete box?
Robert Williams
70' 911T
Old 03-23-2020, 08:55 AM
Awesome, thank you. I was considering ABS as well. To me ABS is almost as easy to work with, and water won't hurt it at all, vs the wood. Not sure there are other benefits either way??
Old 03-23-2020, 12:15 PM
rangrbob
rangrbob's Avatar
The plywood will have a tendency to absorb water and slowly rot or hold moisture if it gets wet, as the ABS will not. ABS will last much longer, and be more durable if you have to put it on and take it off several times during fabrication. I cracked my wood ones doing so.
I was able to use a heavy duty spray adhesive to glue the carpet on my kick panels without any problems. A heavy duty vinyl or landau top adhesive will probably hold up much better though. It is also a good idea to scuff it up with sand paper or Scotch Brite type pad prior, and make sure to remove any waxy or greasy film on it. The biggest down side to the ABS sheet is that it can be quite spendy.
Old 03-27-2020, 12:32 PM
rangrbob
rangrbob's Avatar
Thanks for the link
The spacing for the holes may differ slightly if you are using original or aftermarket VW armrests. The studs are spaced 5 5/16" (13.5 cm) on center for original and 5 1/2" (14 cm) for after market. I used M6 serrated Flange Nuts (pictured below) to hold them against the door. It is a bit tricky to screw them on, as you will have to blindly reach up into the inside of the door while holding the bottom of the panel away from the door. I found it was best to use a 1/4 drive ratchet to tighten them.
The placement on the door itself will be up to where you feel they are most appropriate. Mine are roughly in the center of the door. Unfortunately, I don'd think I documented the measurements though.
Old 03-27-2020, 01:31 PM
rangrbob
rangrbob's Avatar
Bob,
The rear seat delete box is held in by sheet metal screws at the back into the factory location the carpet flap for the seats were screwed to. In the front, I fabricated a removable bracket screwed to the front of the seat pan using 2" aluminum flat sock.
Old 03-27-2020, 01:46 PM
rangrbob
rangrbob's Avatar
[QUOTE= Anything you can show with your technique, materials would be appreciated. Such as sewing your carpet bindings, building the cabinet/structure of your rear seat delete, etc.
Thanks much, John[/QUOTE]
John,
For the binding on the carpet, I cut 2" wide strips off the roll of vinyl lengthwise. I sewed them face down on to the carpet approximately 1/2" from the edge. Then, I folded it over itself and glued it to the back to hold it in place while sewing tight along the edge to finish attaching it. Just a heads up, inside corners can be very difficult to sew. I actually watched a lot of quilting videos for tricks.
To make the binding for the shifter and e-brakes holes, I basically sewed grommets. I sewed two pieces of vinyl face to face, about and inch wider that the hole, cut the centers out, then glued them to the back of the carpet. Once the glue set, I then folded the top piece over and onto the front of the carpet. Gluing it temporarily so I could sew the perimeter. Then I trimmed the excess vinyl as close to the stitching as possible.
I didn't document building the box much at all. I just kinda winged it starting with cardboard templates, then 1/2" plywood. I plunged cut the door with a circular saw and used a piano hinge to attach it. Then fabricated the trim out of 1/2" aluminum angle.
The overall finished product and fit isn't as good as I would like though, and I may build another down the road.
Old 03-27-2020, 03:17 PM
rangrbob
rangrbob's Avatar
It's been slow going on finishing up on the interior. Making progress on the seats. The plan is to add more support and more pronounced bolsters.
Set the passenger seat in to test the height of the foam.
Also decided to two tone the arm rests.
Old 08-14-2020, 08:12 PM
Coachmanship is a lost art!
Having trimmed a few classics in my day, my hats off to your vision and tenacity. Awesome job!
Old 08-14-2020, 09:04 PM
Love the way you modified the seat back to hold the new foam. Well done. Do you plan to cover the top 3”-4” of the seat back with foam over the metal bar like the stock seat or do you have plans for some other approach?
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 08-14-2020, 10:18 PM
rangrbob
rangrbob's Avatar
Thanks guys. Although my vision and design, I can not take credit for the foam work. I am working with an upholsterer as I am a little leery of attempting to do the seats myself.
Brian, I hope to have additional foam to cover the top part of the frame.
Old 08-15-2020, 07:41 AM
