Dropped valve adjusting nut
Dropped valve adjusting nut on cylinder #5 intake side. Any help or guidance is appreciated. Tried a magnet no luck, cant even visually see it. Thanks in advance for any guidance and help.
Tracy
Old 09-17-2019, 05:32 AM
The cam housing doesn´t have holes in it, so rest assured that the nut is there hiding in a crevice. Keep fishing around with your magnet and you will eventually locate it.
David Yerkes
1987 911 Targa - GP White
Old 09-17-2019, 06:47 AM
The 9 Store
You can buy boroscopes that wirelessly use your phone or laptop as a screen. They run ~$25 on amazon and work surprisingly well. They have a very small camera head with a built in LED light. Mine has been worth every penny for the - oh **** moments.
All used parts sold as is.
Old 09-17-2019, 07:10 AM
Dyerkes, sent you a PM
Old 09-17-2019, 07:28 AM
bourgeois911's Avatar
A shop vac may come in handy also.
Tom
79 911 SC
Old 09-17-2019, 07:43 AM
There are exposed holes in the cam housing leading to the oil drain back tubes. If the nut doesn’t appear elsewhere, suspect one of those tubes. Get a light in there and take a look. Good luck.
Sherwood
Old 09-17-2019, 11:55 AM
AutoBahned
RWebb's Avatar
I'd just use a magnet on a flexi-stick thing first
Old 09-17-2019, 04:39 PM
Functionista
manbridge 74's Avatar
If you don’t have a flexible magnet you can make one up PDQ. Use a stiff piece of copper wire (one strand) and insert it into small vacuum line. At the end of the vacuum line stick a small magnet like from a pocket screwdriver achieving a tight fit. The usually powerful magnet can be bent about anywhere.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-17-2019, 05:53 PM
Send a message via Skype™ to Porboynz
I spent ages fishing around for a broken off feeler gauge tip, then found it sitting on the tinwork. Relief.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 09-17-2019, 11:17 PM
Careful with magnets not firmly affixed to your holder. I'd opt for a low-tech, cheapie magnet - just enough to retrieve an errant fastener.
A high-end neodymium magnet will be difficult to retrieve if it's stuck onto an internal engine component.
Sherwood
Old 09-18-2019, 09:33 AM
proporsche's Avatar
if i may ask?..why did you remove the nut from the rocker to do valve adjustment?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-18-2019, 12:18 PM
To clean up the threads on the adjusting stem in order to set a more accurate valve clearance.
Old 09-18-2019, 12:33 PM
Located the nut it had fallen down to the exhaust side remove the valve cover and retrieved it all is well Panic attack is over
Old 09-19-2019, 06:00 AM
pgeorgeson's Avatar
Mighty Worm!
https://www.toolsource.com/pickup-tools-c-614_616/mighty-worm-magnetic-pickup-tool-p-139194.html
I know you found it, but I find this to be an indispensable item in the tool box.
Old 09-19-2019, 08:29 AM
