-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   AEM 30-4110 wideband-02-kit reliability (http://forums.pelicanparts.com/showthread.php?t=1041314)
larrym 09-28-2019 07:02 PM
looking to buy another wide-band kit - had the older AEM 4.2 kit on my 3.2 914-6 & it worked great 4 yrs
the 4.9 30-4110 was supposed to be better :confused:
lots of bad reviews of the 4.9 30-4110 on Amazon, & same for Innovate kit - & once you open the box NO WARRANTY or RETURN
what's the consensus here?
reviving this long older thread
http://forums.pelicanparts.com/porsche-911-technical-forum/895323-aem-wideband-o2-gauges.html
Reiver 09-28-2019 07:20 PM
What failed on your 4.2 kit? Mine is still working after 5 years and about 10k miles per year.
larrym 09-28-2019 07:51 PM
NOTHING failed on the 4.2 see above "....AEM 4.2 kit on my 3.2 914-6 & it worked great 4 yrs" SmileWavy
i want to know about the new 4.9 version's reliability :)
trond 09-28-2019 10:58 PM
my AEM 4.9 kit died within days. Previous LC-1 kit with 4.2 sond was still working fine after some 6 years. Uncle google suggested the 4.9 could be more sensitive to condensed water in exhaust hitting the already fully hot sensor. Sensor heats very quick after ignition is switched on. I rewired and now AEM gets power via relay with time delay. It now starts 30 seconds after engine. No further issues with sensor. My time delay is in the MS2 ECU but could be as simple as a switch. Just avoid starting cold engine with a hot sensor. To be considered
larrym 09-29-2019 10:40 AM
AEM 4.9 failure solution
brilliant! - thanks
uncle google <12V time delay relay> says there are plenty of options to buy SmileWavy
for example 12v 30-sec H3Y-2 on ebay
