AEM Wideband O2 gauges
I highly recommend having a WBO2 gauge in any of the 911 air cooled cars but not all gauges are created equal.
Always use the more modern style gauges that utilize the LSU4.9 sensors and not the older LSU4.2 sensors. The LSU4.9 sensors NEVER need free air calibration. The product line I really like is the AEM gauges: Wideband UEGO Air/Fuel Controllers | AEM They have both digital and analog style gauges as well as a really neat new gauge that actually uses a smart phone over WIFI. The phone connects to the WIFI gauge controller and the AFR data is displayed on the phone, no wire connection between phone and gauge. I have had several folks tell me they don't want modern gauges installed in older cars, I think the WIFI gauge solves this problem. Here are the AEM gauges: Digital and cheapest, plus it's the LSU 4.9 better sensor: Same as digital but with Analog gauge, older 4.2 sensor: The WIFI version, more expensive, older 4.2 sensor: The AEM product for the money is very high quality and has excellent heater control for the sensor. Heater control is important for the sensor's longevity. I also like the TechEdge products WBo2.com WIDEBAND AFR/LAMBDA (Tech Edge) but these products are for tech savy folks only! Very powerful but not easy to setup. Plenty of other decent brands around, just be sure you get a LSU4.9 sensor gauge. Hope this helps others looking at adding a WBO2 in the cockpit.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 06-06-2016 at 10:22 AM.. |
I've got this one in my car, has USB for datalogging and will cut boost if you go lean:
Wideband Failsafe Gauge | AEM
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
Yes, this one is also very nice with added features. I assume you are happy with it?
Also this gauge can log and includes RPM input, correct? Quote:
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 12-17-2015 at 11:32 AM.. |
Sal, I got the AEM WBO2 gauge per your recommendation. Waiting to install it with my SSIs. Then, your MAF and chip!
Steve |
Are the cables on these enough to reach from the O2 location to the cabin for the guage? Or is splicing necessary?
1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html |
If you place the gauge in the center console or below the ash tray and run the cables straight shot to the O2 sensor they reach.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Using Wideband O2 instead of CO meter
On a CIS car can I use a Wideband O2 sensor instead of using a CO meter to check and adjust my mixture? O2 is measuring fuel to air ratio, and CO increases with a richer mixture, so am I getting essentially the same information by using either? The O2 sensors seem cheaper and easier to come by.
79' 911 Targa 07' Cooper S 03' E46 M3 sold 96' E36 M3 sold 81' XS-650 Bobber sold |
Yes, you can use a WBO2 to setup a CIS car. I have a cross ref document for CO to AFR.
Here's a few values: %CO AFR ---------------- 0.1 14.72 0.2 14.54 0.3 14.42 0.4 14.34 0.5 14.28 0.6 14.23 0.7 14.21 0.8 14.17 0.9 14.15 1.0 14.11 1.1 14.09 1.2 14.04 1.3 14.01 1.4 13.98 1.5 13.94 1.6 13.89 1.7 13.86 1.8 13.82 1.9 13.80 2.0 13.77 2.1 13.73 2.2 13.69 2.3 13.63 2.4 13.59 2.5 13.56 2.6 13.54 2.7 13.49 2.8 13.45 2.9 13.41 3.0 13.38 I think base mixture on the CIS car is set at around 14.2AFR +/- 0.2 Quote:
AFR to CO
Great, thanks for the info. Looks like I need to get an O2 sensor.
Bently
The Bently manual says the idle mixture CO% should be 1.5 to 3.5% at 950 +/- 50rpm, so that would be 13.94 to 13.2
79' 911 Targa 07' Cooper S 03' E46 M3 sold 96' E36 M3 sold 81' XS-650 Bobber sold Last edited by gregoryp; 12-17-2015 at 03:48 PM.. |
Please excuse my ignorance (and laziness). Can you explain where the wires enter the cabin and what the place is to grab power from?
My wires come in with my wiring harness, and run under my drivers seat. I temp mounted my analog gauge in the centre console, but i am now deleting that, and will try to place it with two more gauges where the radio was.
Mine is ground in the passangers floorboard screw, and links into my ignition. I forget the other spot. Well worth the money.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
I like the Daytona-Sensors instrument sold by PP a lot better. Very well built, very reliable and great customer support. Very good data logging and software as well.
if you have CIS, MFI, or carbs.....you need a good AFR gauge
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
I had a LC-1 in a turbo'd Miata project a while back. It needed free air calibration very often, even with a new sensor. It was a complete PITA.
Just placed my order. Been putting this one off for a while.
Agree with taking the sensor cable to the rear of the car via the existing wire harness just below the rear LHS seat, the wire will fit into that existing hole in the 84-89 cars.
The gauge then needs power and I recommend extending the power and ground lines up into the front truck and then ground and power it at the fuse box. Tap power into an existing fuse lug, find a fuse with power in 'RUN' like the Cigar Lighter fuse #6. I recommend this fuse since most never use the lighter and it has plenty of spare current capacity. Tap the hot side of the fuse, the side that has power with the fuse removed. Then put a 10amp inline fuse on the line that feeds the gauge. Or you can simply power the gauge directly from the cigar lighter in the cockpit, I just don't like cutting or tapping wires so I recommend the fuse block as a better approach. I've also had folks turn the gauge into a temporary install to move in and out of other cars. Some put a cigar lighter adapter on the power/gnd lines and simply plug into the lighter. You can also put the gauge in a temporary 2" pod and velcro it to desired location. Then run the line to the sensor out the rear side window and tape it to the side of car with blue painters tape. Of course this is only for temporary quick install. You can also put alligator clips on the power/gnd lines and power it from the fuses in the engine bay and have the gauge right at the engine bay, this works well if you just want to use the gauge to set base fuel mixture in a CIS or Motronic car. My personal in car gauge is mounted in a small 2" round pod and sits on the very far LHS of the dash against the pillar. I like it here because it's in my line of site at all times. The pod just sits in the corner and held in place with a tinny piece of velcro to the windshield post. Quote:
Agree! The LSU 4.2 sensors often need recalibration, the LC-1 often needs recalibration and you MUST take the sensor out of the exhaust stream to calibrate it, you can not calibrate the gauge with the sensor still in the bung. Huge pain!
Here's some pics of cars with the gauge in cockpit:
My personal car: ![]() This is one in the center console: ![]() Maybe others will post more pics.
Chain fence eating turbo
Hey Sal, does your CO readings account for E10 gas? Good info there!
