disband
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Mighty Meatlocker Turbo
disband
shug's back from his most recent week or so banning for bad behavior in name calling and/or duchie-ness. he'd see me welcoming him back, but im on his ignore list reportedly.... im sure he peeks from time to time...
Hey Tobz, speaking of showing off, remember a certain someone who internet-diagnosed yer 911's cracked cylinder, like a BOSS?!?!
If using a Motive pump what do you use to clamp the release tubing? Forceps?
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
Formerly known as Syzygy
Vice grips work well for that.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I use two chucks of wood (prevents damage to the line) and vise grips to close the line.
Gravity bleeding works well....and you can work on something else while it is bleeding.
regards al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
OP, did you also rebuild the calipers and install new seal rings and dust boots? When I did that recently, the new dust boots were stiff enough that they would pull the pistons back extra far, so that the first pedal application was really soft and almost to the floor. Once stretched out (wedging the brake pedal down overnight worked) the pedal firmness came right back.
Jeff Jensen 1973 911 |
Slippery Slope Expert
For closing the vent line a small C clamp works well too.
Whatever you use it needs be able to apply some force as the vent line is thick wall and by this time hardened with age. (Too bad we don’t do that . . . )
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Air bubbles during gravity bleeding:
Sherwood |
Troll Hunter
I've bled my 72's brakes 4 times using a Motive. Still have spongy feel, kinda like Ronnies blow up doll or Sugardopes brain.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
![]() But about your brakes - are you pumping the pedal from time to time (bleed fittings closed, of course) during the process? That helps move some trapped air along.Besides, non-turbo 911s don't really need brakes (aka - they're soooo faaaccckkkiiiiinnnnn sloooooowwwwwwwwwwwww - just like the gravity bleed method!!!!)! |
In a closed system, air bubbles tend to stay where they are. Only when fluid flows or the system recognizes gravity will bubbles tend to follow.
In some cases, internally swollen (constricted) flex brake lines will restrict fluid flow while inhibiting slower moving air bubbles, reducing the effectiveness of most manual or pressurized bleeding operation. |
Anyone feeling motivated to make this?
If so, please list the exact part numbers you buy from Home Depot http://forums.pelicanparts.com/porsche-911-technical-forum/427910-5-pressure-bleeder.html
1986 Bosch Icon Wipers coupe. |
disband
exact numbers? come on shug…. you'd need to determine what quick disconnect air fittings you use so each application would not be exact. one size does not fit all.
Still here
And the super simple attachment. Just turn your compressor reg down to 15psi and wire the blow gun open.
![]() And even with this I had a hard time getting all the air out of a completely new system. Air pockets kept showing up. It took two or three different evenings of going through all four corners to get it right.
Derrick Last edited by 1979-930; 01-02-2020 at 10:49 AM.. |
Home of the Whopper
I use the compressor method, but only at about 5psi. Like others have said, gravity works fine. But a little extra works a little quicker. I also use a drain bottle a bit smaller than the MC, so I can't drain the MC.
The next time I do brakes I think I'll hire pNutz - hooking his saucy lips up to the res ought to make quick work of the job! And if he needs help, Deez will be happy to ablige!!!
