Keen 915 operator
Fabric heat exchangers?
I run headers on my '82, and I have to say I kind of miss having heat from time to time. If I had the funds I would definitely switch to SSIs, however money is an object for me.
Hence, I wonder if anybody has tried making semi-removable heat exchangers from heat resistant fabric (such as fibreglass fire blankets)? I'm thinking of wrapping the headers in a couple of those, one for each bank, and securing them with some long hose clamps. What do you think, is that a stupid idea or could it work? I'm not aiming for tropical heat in the cabin, only something to keep me a bit warmer in outside temperatures of, say, 10 degrees Celsius (50 F). |
Id think you would want to use a material that is a good conductor. If I were looking to add heat to headers I'd use 2.5" x .06" (or thinner) wall stainless tube and hose clamp it to the longest, straightest section of the header. Connect your flex hoses to the in and out and you'll get 'some' heat.
1978 SC Targa |
Under the radar
Cheap heated seat kit or heated seat covers instead?
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
I recall seeing a SC for sale on here a while back with a stainless flex tube that was clamped to the headers. Seller (I think username was Mingus. Why do I remember that?) said it was enough to take the chill off and keep the windscreen clear - something like this should work if your expectations are low enough.
Under the radar
I’ve thought of doing the same thing and have found some threads where others have done it. Also I’ve looked into clamp on heat exchangers from the aviation industry. I’m in Florida so its not on the top of my list to get it done. Search heat with headers you should find some ideas. Here’s a pic from one of the threads
78 911 st backdate 87 944 00 996 |
Keen 915 operator
