al lkosmal's Avatar
x-faktory 2.2E to 2.5SS
It's a filthy bugger, but should clean up nicely......with lot's of new, shiny bits on the shelf......tearing it down, with heads going to CGarr shortly for rebuild, case headed to Ollies......and much more.
stay tuned.....
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 02-19-2020, 09:02 PM
I would rather be driving
jpnovak's Avatar
I have a 2.5SS planned for my SWT targa.
What's the engine plan?
MFI? Cams the same?
Old 02-21-2020, 12:05 PM
al lkosmal's Avatar
MFI? Cams the same?
jamie,
Lot's of ways to go here, but....MFI...yep. The E-cams...likely.
thinking about heads, etc....
regards,
al
RGruppe #669
Old 02-21-2020, 05:53 PM
al lkosmal's Avatar
a slight return
Wow....this project has been on hold for quite a while.....while awaiting the return of the case from Ollie's....lot's of work required on the 2.2E case. in addition to the usual machining, opening the spigots, time-certs, oi squirters etc...this required align boring, machining back to standard, a bit of welding.....and on and on.
In the meantime, I've been getting all of the bits clean, powder-coated and so on.
Today, I blew the dust off of my injector tester/cleaner and cleaned and tested the MFI Injectors.
I bought this device about 10 years ago from a company that specializes in older Mercedes. They built these testers for the diesel injectors.....but they work well for the MFI injectors and I've made adapters for CIS injectors and even EFI injectors.....very handy as you can simple testing of opening pressure, spray pattern and clean out the injectors with this thing........
RGruppe #669
Old 07-28-2020, 04:17 PM
abit off center
cgarr's Avatar
That’s an interesting setup, I have a few of those kicking around might just have to do some machining and conversions
______________________
Craig
G2Performance
Old 07-28-2020, 04:22 PM
pressure tester
I have similar setup and works great.I have a pedal cluster with master cylinder to push the pistons out of calipers for the last 45 years for the bench to rebuild brake calipers.It is cool to be a TOOL.Like Nietzche said you are what you pretend to be sometimes.Ciao Fred
Old 07-28-2020, 04:42 PM
al lkosmal's Avatar
I just checked and the company that I bought that tester from is still in biz...here's a link..
https://mercedessource.com/store/cis-gas-fuel-injector-spray-pattern-tester-and-nozzle-cleaner
I like the master cylinder idea Fred......
regards,
al
RGruppe #669
Old 07-28-2020, 05:12 PM
al lkosmal's Avatar
about flippin time
Well, at long last, I've received the 2.2-2.5 case back from Ollie's......shipped it out on 03/30, received it back this week....Just shy of 6 months and lot's more work required than I anticipated. Definitely the full-meal deal on this one, but as usual, their work is a thing of beauty.......
Test fit one of the cylinders....like butta!
Onward with the build!
RGruppe #669
Old 09-25-2020, 10:17 AM
Awesome!!! I am so looking forward to seeing the final product. Brad has let me drive "The Bean" on a few occasions, and it was fun as hell in 2.2 E trim. This motor will increase that fun factor several fold. A screaming' 2.5 SS seems like the perfect fit for that car. This is going to be so cool...
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 09-25-2020, 02:56 PM
al lkosmal's Avatar
Jeff,
I am really looking forward to this build..........this should be nothing but fun.
Jumping ahead.....I'll be doing the prelim burn-in/tuning on my test stand and then down to the Shop for install into Brad's 911. We may need to call on the "MFI whisperer" to dial this baby in.
regards,
al
RGruppe #669
Old 09-25-2020, 05:41 PM
al lkosmal's Avatar
progress.
Making progress with the 2.5SS project...starting to look like an engine again.
stay tuned,
al
RGruppe #669
Old 10-18-2020, 11:56 AM
Can't wait to see this!
Old 10-19-2020, 10:04 AM
I'm feeling like a kid at Christmas, and it isn't even my motor.
Jeff
'72 911T 3.0 MFI
Old 10-19-2020, 02:02 PM
al lkosmal's Avatar
Jeff,
I know what you mean......this one is very cool.
al
RGruppe #669
Old 10-19-2020, 02:48 PM
al lkosmal's Avatar
closer
Getting closer to 2.5SS MFI goodness.......
One minor issue........as I was starting to clean up the tensioners....one of them is missing the small part that must be press fit into the top of the tensioner. Is this a pressure relief valve or? Can it be repaired? Does anyone have the part that gets pressed in?
RGruppe #669
Old 10-20-2020, 04:49 PM
al lkosmal's Avatar
Testing...testing
The 2.5SS is a thing of beauty....I just need to finish installing the MFI stuff and dial it in and then....it's run-in and test time.....
regards,
al
RGruppe #669
Old 10-27-2020, 04:34 PM
Beautiful! Can't wait to hear that bad boy run...
Jeff
'72 911T 3.0 MFI
Old 10-28-2020, 08:14 AM
al lkosmal's Avatar
ready????
I have the 2.5SS on the test stand.....ignition is wired up and fuel is plumbed...however, my regulator is not able to regulate my Carrera fuel pump low enough to meet the MFI spec.....I need to install a lower pressure pump om monday. I couldn't wait, however and shot some starting fluid down the stacks to verify things were hooked up correctly...oil pressure was present etc......fired up 1st try, oil pressure looks good, etc....and it sounded great...for the few seconds it ran. I'll have to wait until Monday to run it in, test/tune etc. Stay tuned!
regards,
al
RGruppe #669
Old 10-30-2020, 05:43 PM
al lkosmal's Avatar
it is ALIVE!!!!!!
today, I fired up the 2.5SS, ran it in a bit, preliminary tune/test, adjust, timing etc...It starts, idles, revs....good oil pressure.....all the important ****e is very good.....it is ALIVE!!!!!
regards,
al
RGruppe #669
Old 11-02-2020, 01:21 PM
Oh my that engine sounds so smooth, and looks very smooth too.
Okay, I know it's the build and not the oil.
Gotta ask, what oil are you using?
Old 11-02-2020, 02:16 PM
