Got my spring in the mail last week. I just put it in along with some fresh bushings. It is great. Thanks Karsten!
Also, this was a factory short shifter, I had an extra stick - I cut it right after the bend and welded it on. Tall stick now! I have an extra tall rennshifter with a top mount knob on my other car and this feels pretty close to it! Can't wait to take it for a spin tomorrow.
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
Nice, waiting on mine.
Karsten,
Sent you a PM from Germany, your neck of the woods. Scott
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
Karsten,
Just wanted to say thank you for your spring. We installed it and it works really well - I like the feel quite a bit and it is such a great idea. Take care and thank you again! Pete
Pete, Park City, Utah, USA - Experience level: Low but eager to learn ![]() - 1986 911 Carrera 3.2 Targa - 2018 Factory Five Mark IV 5.0L Coyote |
Karsten, spring arrived in my neighborhood the other day, Lol, will hopefully put it in this weekend, thanks !
I did install the spring today, it took 10 minutes for the spring , and ....the rest of the day for disassembly and reassembly of the console of my 86 Targa with AC. What a pita...
Regarding the spring, I did not like the 'visa-grip' method to mount it. I used a bent steel rod instead with one end in the spiral, and the other side resting in the 'U' of the spring. Less brutal method. That took 1 minute of the 10 minutes mentioned, the other 9 minutes were failed attempts with the vise-grip that I could not push deep enough to snap the spring in place. Went out for a drive, and this simple mod works great! No more guessing where the shifter is . Tnx Karsten!![]()
azul_minerva
Hey Alex,
Thanks for the hint with the steel rod - a smart way to get the spring in position! Enjoy it now and stay safe Karsten Quote:
______________ Karsten a backdated 1978 SC shell, a 2.7 with carbs and a couple of other Frankenstein mods https://www.instagram.com/azul_minerva/ |
Update. Several months after I had hoped to do this, I finally got around to installing Karsten’s spring and my shifter gate for the 1-2 gears, copied more or less from the Seine Systems gates.
So now I have a 915 with gates on 1-2 and no tension on the selector mechanism in the gearbox. Best of all worlds. You can read about the instal in my thread on the Early S forum. https://www.early911sregistry.org/forums/showthread.php?155077-Converting-to-a-gated-shifter&p=1071850#post1071850
1973 911 S Ivory White, 5sp MT 2023 Macan GTS Gentian Blue, 7 sp PDK |
As Karsten stated before, he discussed the spring tension to a few of the old 911 gurus that worked for Porsche In the day and they said it had zero impact to the transmission.
While it is 2 minutes work to remove the 1-2 gate, I see no downside and the upside is it works exactly as Porsche designed the 5-R side.
1973 911 S Ivory White, 5sp MT 2023 Macan GTS Gentian Blue, 7 sp PDK Last edited by NorthernThrux; 09-13-2020 at 06:35 PM.. |
Lash
Installed mine a couple months ago and have driven more than two hundred miles since installation. Great improvement for 915 tranny.
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
I was in Germany last week and spoke to a German Porsche wrench that worked in the race department for Porsche in the 80-90s and now has his only shop outside Würzburg.
I spoke to him on the spring and he also confirmed the stress/wear is not for one to worry about. Armin is a well know expert and I will trust his opinion. Scott
I’m sure you are right. Even if there is wear, other parts of the gearbox will wear faster, so it’s unlikely to be a failure mode.
I do wonder why, when Porsche was cutting corners left, right and centre in the early seventies and had just redesigned the shift tower for 1973, that they went through the expense of keeping the gate tabs and the corresponding tab on the gear lever, and indeed kept them all the way to 1989 I think. There has to be a reason. It could just be a NVH issue. The tensioned gear lever would vibrate more without a hard point to rest on that the tabs provide.
Just to clarify my earlier post. Porsche went to the trouble of adding the gated tabs and spring loading on 5 and R in 1973. The 1972 and earlier 915 and 901 shifters didn't have it. So unless they were high on German beer, there was a reason for this decision.
@NorthernThrux - You are making your kit available? Cost?
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Nope, sorry. I have a day job. This is just a hobby.
You could buy the Seine systems gate kit and only use their bracket in addition to Karsten’s spring. But that would kinda defeat the cost effectiveness of his solution and mine. Maybe people can convince Seine to sell only the bracket and the tab that welds to the gearshift for a reasonable price. I’m a firm believer in keeping our innovative vendors in business, so they are there to develop solutions for our cars.
PRO Motorsports
You can spend hundreds of miles driving in 5th gear. With the spring tension pushing the lever over, and the lever unsupported, it can transmit a lot of noise into the cabin. With my Wevo shifter in my race car, in 5th gear it fairly noisy, but if I push the lever to the right to relive the spring pressure, it’s significantly quieter. (Doesn’t have the gate shift)
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Tyson, That's consistent with something Ed Mayo mentioned on the ESR Forum. The '72 915 had a whine in 5th gear apparently that could be silenced by pushing the gear lever over a bit or playing around a lot with the linkage. But it doesn't explain why R has it too. Most people would not even reverse a mile in a lifetime of driving their car. OTOH they would never spend enough time in R to wear anything out either. So it's a bit of a mystery.
spring
Hi, great idea, you have a PM.
Behind the wheel in my US imported 81 SC with 3.2L swap. |
