Free or Cheap Projects While Quarantined
Hey all! I really want to work on my car while stuck at home but I have no foreseeable income to fund what I really want to do. So what are some free or cheap things I can do to the car during this lock down???
Old 04-06-2020, 04:46 PM
Bill Douglas's Avatar
Inspect and clean the spark plugs.
AND when was the last time you lubed the door hinges LOL
Old 04-06-2020, 05:08 PM
valve adjustment is almost free.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-06-2020, 05:09 PM
Perpetual Reassembler
2jmotorsports's Avatar
Find electrical stuff that doesnt work and fix the wiring.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 04-06-2020, 05:23 PM
911 enthusiast
tmadden2's Avatar
Rejuvenate anything leather, vinyl, or rubber. Fuse circuits that need them.
Old 04-06-2020, 05:35 PM
Yes clean your electrical grounds
If you give your word: keep it.
Old 04-06-2020, 05:42 PM
I would rather be driving
jpnovak's Avatar
flush brakes. Rebuild calipers.
detail car.
Start working through 101 Projects list.
Old 04-06-2020, 05:52 PM
walt's Avatar
Adjust parking brakes, lube seat sliders.
Walt
82SC 3.0
81SC 3.6
Old 04-06-2020, 06:07 PM
'73 911 T Targa
Check and clean your battery terminals.
I left my wife’s 3 year old daily driver in the driveway for a few days and it wouldn’t start when I came back to it. The battery posts and connectors were horribly corroded.
Old 04-06-2020, 06:33 PM
'73 911 T Targa
What would you use for this?
Remove door panels, lubricate internal door latch and window mechanisms. Reinstall door panels. Enjoy.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 04-06-2020, 10:14 PM
Did the AFM check - found that is had a small discontinuity around 25%-30% opening and proceeded to remove the AFM (airfilter first), open it and retrack the wiper. Everything looks top now (no jump visible) and matches the voltage table it is supposed to read.
However, since I have no silicone in the house, I cannot put the cap back on. Waiting for the online store to deliver but it could be up to 2 weeks...
Did the leather...
Did the spark plugs...
Cleaned the wheel wells & underside...
Good idea to remove the door cards, I can adress the small rattle in there too !
Old 04-06-2020, 11:31 PM
Ctopher's Avatar
I used Wurth HHS2000 for sliders, door hinges, etc.
Old 04-07-2020, 04:18 AM
Troll Hunter
Every few years, or when I think of it, I lube everything I can think of while walking around, under and through the cars. Door locks, hinges, trunk latches, joints whatever.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 04-07-2020, 06:00 AM
Remove motor and tranny disassemble and see how things work. Report back to us with a single spaced 10 page essay. You will be graded on grammar.
Old 04-07-2020, 06:34 AM
(man/dude)
Jonny042's Avatar
LOL. As funny as that is, doing a "drop" doesn't cost too much in itself, always a good way to take care of stuff, find vacuum leaks, etc. I've done one every spring for the past few years on the Autocross car and always find something to do. Mind you it was never cheap......
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-07-2020, 06:40 AM
Pedro '84 Coupe's Avatar
Painted the fresh air intake grille on the cowling. Was starting to fade to silver, now it's flat black.
2000 Boxster S and 2016 Audi A6
Old 04-07-2020, 06:44 AM
in addition to tranny internals inspection, check/add blinker fluid, and R&R that pesky muffler bearing...
Old 04-07-2020, 06:47 AM
I use a silicon spray to treat all of the door and trunk seals, do this every year
Old 04-07-2020, 08:50 AM
I had considered doing a drop to check things out but I know that I won't be able to put it back in should I find something but can't afford to replace it!
Vacuum leaks seems pretty easy, would need a smoker type device though. I KNOW my pop off valve is leaking.
I have the velvet strip for the sunroof too, maybe get some adhesive and get that looking good!
Old 04-07-2020, 03:33 PM
