Intermittent tach '84 3.2
This morning I was driving on a particularly bumpy road and over some railroad tracks, and my tach went dead. It came back to life a few seconds later and indicates correctly, but is now dropping out intermittently. Car starts, idles, and runs perfectly, so I'm assuming the bumpy road caused a connection issue somewhere. A few weeks ago I pulled the bulbs out of the climate panel, as they had pulled out of their respective tubes and I didn't want them heating up any wires back their and have been dreading the process of getting under their to sort it out. If any of those wires were grounding out can that cause a tach issue?
Any suggestions on where to start, or just work my way back from the battery?
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 04-24-2020, 08:26 AM
Newbie
Send a message via AIM to 0172XCarrera
Chances are it had nothing to do with changing the lighting or a ground. There are plenty of articles or posts here on Pelican indicating that this is a relatively common or "normal" thing that occurs with the Tach's over time. I had the exact same issue in the summer of 2018 with my 84 3.2 at just under 70K miles. My mechanic confirmed what I had read here that it is relatively common and the plastic gears inside the tach become brittle over the years and can break. He just happened to have a couple of re-built tach's at his disposal because he gets a few every season. I swapped it out with a rebuilt / reconditioned one he provided and problem is gone. No re-occurance in about 1,500 miles. If you feel confident enough to do it yourself - its pretty easy and there are a couple of very reputable shops on the west coast that rebuild them. Otherwise, if you have a mechanic that works on air cooled 911's regularly, he or she should be able to hook you up. Good luck!
Old 04-24-2020, 02:26 PM
If the gears break wouldn't it just die completely? It's dropping out maybe 10% of the time, the rest it's reading engine speed perfectly, not bouncing at all.
Old 04-24-2020, 05:10 PM
There're no plastic gears in any Porsche (air cooled) tachs.
Dave
Old 04-24-2020, 06:16 PM
The plastic gear he's referring to is in the speedometer and it only effects the odometer not the speedometer.
I would guess you're first inclination of a lose connection is probably right. There are only 3 wires on the back of the tach that matter. 12V, ground and the tach signal. You can check the 12V and ground with a meter and if those are good confirm a good connection of the tach signal. On a 3.2 the tach signal comes directly from the DME.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 04-24-2020, 07:19 PM
Not really! It's explicit in this statement that he's referring to a tach;
"Originally Posted by 0172XCarrera View Post, My mechanic confirmed what I had read here that it is relatively common
and the plastic gears inside the tach become brittle over the years and can break."
Unfortunately his mechanic doesn't know much about Porsche tachs.
Dave
Old 04-25-2020, 07:46 AM
Keithg's Avatar
Our 84 just had same issue. $130 repair at No Hollywood shop.
Old 04-25-2020, 08:38 AM
Are there any fusebox wires I need to check? I'm working my way backwards from the battery. Positive battery cable doesn't fit down on the terminal very far (Odyssey PC925 terminals are kind of odd) and I need to make sure that connection is solid and rule it out as the issue.
Old 04-25-2020, 09:01 AM
Pedro '84 Coupe's Avatar
I sent the tach off for repair when I got mine too. It was intermittent until it finally died one day.
2000 Boxster S and 2016 Audi A6
Old 04-25-2020, 09:24 AM
The tach signal comes from the DME (black and purple wire), pin 21. Sounds to me like the gauge itself needs to be looked at. When I sent mine to NHS for repair, they didn't say what was wrong with it but I suspect a bad solder joint. Do you know of anyone close by that could loan you a working 3.2 tach?
Old 04-25-2020, 09:30 AM
I would just confirm a good 12V and ground at the tach. You will spend all day starting at the battery, unless you are trying to track down other issues. If you have a good 12V and ground at the tach then just double check the black/purple wire to make sure you have a good connection. If you don't find anything external, I too would suspect a bad internal connection. Borrowing a known good tach is a good idea.
Old 04-25-2020, 10:03 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Check your running voltage. Wonky alternator will crisp up your tach among other things.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-26-2020, 10:45 AM
Discseven's Avatar
Originally Posted by clickclickboom View Post
check your running voltage. Wonky alternator will crisp up your tach among other things.
+1
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 04-26-2020, 11:33 AM
Newbie
My apologies for my earlier post where my recollection of information about there being plastic gears was incorrect. That said - the changing of the tach for a rebuilt unit resulted in the problem going away. I will refrain from providing comments in the future when I don't know what I'm talking about. Sorry for any confusion I may have created.
Old 04-26-2020, 11:47 AM
