Targa_PB_78_SC
mike sampsel's Avatar
Leak from cooler seals?
After correcting TOD and case defect leaks I’m left with a little drop of oil buildup per the pic.
It is coming from the seam in the cooler and engine case directly above. Would appear to be oil cooler seals leaking.
Is there a solution with engine in car? Loads of JB weld on the seam maybe?
Old 10-25-2018, 10:10 AM
proporsche's Avatar
Hi what kind of o rings did you use? Green Viton is correct type...Did you repair while you had the cooler of this place ? marked black circle..
1985 911 with original 502 191 miles...808 198 km
Old 10-25-2018, 10:55 AM
proporsche's Avatar
here is a official info...
Old 10-25-2018, 10:57 AM
I would rather be driving
jpnovak's Avatar
Pull the oil cooler and check the seals. Can be done in the car. Easier if you remove the Pass side rear shock. Very straightforward.
Old 10-25-2018, 11:14 AM
Targa_PB_78_SC
Thanks guys. Thinking the plastic cooler cover plate has to come off to remove the oil cooler.
I have never removed my cooler yet. Might do so sometime, glad to get your inputs. Seems there is more work to consider at next oil change.
Old 10-25-2018, 11:49 AM
Remove all the plastic cover screws as possible, leaving the inner ones you can't get to, then just lift up the outer edge to get at the top 2 cooler nuts.
206 637 4071
Old 10-25-2018, 12:23 PM
Targa_PB_78_SC
thanks for sharing your knowledge. I’d of never thought of this approach.
Old 10-25-2018, 04:52 PM
Targa_PB_78_SC
Recommend the green Porsche seals, or are the other seals okay too?
Old 10-25-2018, 05:36 PM
disband
juanbenae's Avatar
no.
has the cooler been out before under your watch? the rubber can get tired, or if you installed new and were not careful you can displace/pinch and they can be prone leak. the cooler looks super clean, was it sent out?
if there is no evidence of old, pinched cooler seals upon removal id consider sending it to pacific coolers for testing and cleaning. if one leaks they can braze stuff on the outer seams, others are considered junk if they can not repair it. they will send it back for reinstall if you can stand a cleaned cooler the drip,,, drip, drip.
t
Old 10-25-2018, 06:45 PM
Mike. If you pull the cooler, wire brush the recess behind the cooler and JB weld coat the pipe recess as in the bulletin
Bruce
Old 10-25-2018, 06:53 PM
JBWeld
Picture of current build seal behind the cooler
Bruce
Old 10-25-2018, 06:59 PM
Targa_PB_78_SC
Bruce
Shame this work of JB weld Art has to be covered up with the cooler!
Since my recess leaked on the outside, it seems quite likely it’s the case defect behind the cooler causing my leak. Ho hum, might leave this to the rebuild some day. Unless I get bored for an interesting project.
Old 10-26-2018, 06:07 AM
proporsche's Avatar
Mike ..only Green seal should be used..The name is Viton.
Since you will be replacing the oil cooler seals apply the JB weld on the inside and outside..as Bruce said
Ivan
Old 10-26-2018, 06:14 AM
Put a piece of duct tape over the uncured JB weld to keep it from sagging until it hardens.
206 637 4071
Old 10-26-2018, 06:46 AM
Targa_PB_78_SC
Seems there is no urgency to repair the leak on the interior recess. Or is there a risk of catastrophic failure from letting it be?
Old 10-27-2018, 11:04 AM
Does this have to be done on a 2.7 case?
Old 06-09-2020, 02:48 PM
Nevermind I just took my oil cooler off and I guess my mechanic did it when I did the rebuild.
Old 06-09-2020, 05:13 PM
