Spark Chaser's Avatar
jlex, one side of the repair area is accessible without removing the cooler. Unfortunately to repair the other side you will have to remove the oil cooler as highlighted in flojo’s previous post. I just did this on my ‘88.
Larry
'88 Coupe
'66 Mustang Shelby GT 350 Clone (sold)
Old 06-10-2020, 11:15 AM
Flojo's Avatar
Originally Posted by jlex View Post
But this would require taking off the oil cooler first, right?
to go 100% yes.
but you don't go through the husltle just for that check.
if you have a light leak, adress it next time you drop the engine for some other reason
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 06-10-2020, 11:47 AM
proporsche's Avatar
flojo........ your quotation is out of contest ..he was asking if he can see the outside of the case without taking the oil cooler off and the answer is yes you can see it without taking the oil cooler off..Just to clarify it for future onlookers;-)))))
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-10-2020, 11:56 AM
Larry: Sounds like it's a problem on the '88 too if yours has the original engine...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 06-10-2020, 05:27 PM
Url Url is offline
Url's Avatar
What I did as I want to be 100% sure this area remains dry:
1. Sent out the oil cooler for pressure testing (Expected to have it back today)
2. Sealed the case with Versachem Titanium Epoxy System
3. As there was a comment on the usage of green seals, I picked up new ones from the local Porsche center => For comparison (Big seal is a different green than the old one, suppose it doesn't matter but wanted to use new seals anyway)
And while I was in there, I installed a new damping mat as the old one was completely dry and crumbling
Old 06-17-2020, 01:37 AM
proporsche's Avatar
good job....
Old 06-17-2020, 04:20 AM
