The intake manifold bolts were indeed quite loose, the worst was at about 10nm torque i would say. Had to tighten them by hand because lacking some parts to my torque wrench, but got them to about 20-30nm by hand.
Wen't for a test drive after all the stuff mentioned above and the result was the same as always with misfiring from startup which ended after 10 minutes of driving and the engine heating up. Today was a warm and dry day so the misfiring has evolved to the next level it seems. One thing i noted today was that after a hard 2nd gear pull i get a loud backfire when changing to 3rd. The car was also backfiring when downshifting and such. Not too much but it was noticeable when driving windows open. After that i was fed up and decided to try to alter the fuel to air ratio manually from the dme. Changed the fuel quality switch from the motronic to position 3, which lowers the amount of fuel coming to the system by 3.9% it seems: https://www.911chips.com/fuelsys.html After that i got the first cold start in a month without misfires! The car run very nicely and didn't backfire noticeably after hard pulls, some backfiring still sometimes i.e when rolling downhill while engine braking with about 3-4k rpm. This probably isn't the best long term solution, but proves that the engines air to fuel mixture is off by quite a bit. Could it be a faulty or dirty air flow sensor? I'm seriously running out of ideas, could the valve guides be still the cause? |
hi,when was the last time you did see the C/O fuel mix being set?And what is is it set up to?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I would start with that ,to do that you have to go to pro Porsche shop or anybody who has a gas analyzer to set your fuel mix....this is the basics, before you start trouble shooting...
If that has not been done on your 911 you might have to remove AFM and remove the factory plug.Under there is a adjustment screw to correct the fuel mix... look here ![]() Also to set the correct fuel mix you have to measure before catalyst-if you have one on your 911...and oxygen sensor disconnected..which you can actually leave disconnected -i do not know how is in Finland with smog tests every 2 years?
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 07-27-2020 at 12:48 AM.. |
to set the idle...
And my 911 does not have a catalyst or oxygen sensor so that makes the procedure a bit easier. By the way, today was very rainy day and the misfires came back. They weren't as bad as before and stopped at about 50⁰C oil temp instead of 70⁰C as was the case before the motronic adjustment. |
Loose intake bolts will cause rough idle And a mis that will get worse over time. I had the problem. A very experienced a Porsche mechanic in San Diego told me to tighten them up and it did the trick. After several years on a 3.2 the bolts became loose. Common.
you are so funny............ "unofficial hack"..dude those are Porsche factory pages.It is basic maintenance(usually once in a year or 2 years) to check the C/O level and adjust ....i`d bet your needs to be adjusted...
for you miss when is raining or wet ...start with you spark plugs connector..when dry weather Use spray bottle and when the engine is running spray on each cylinder at a time.trying to duplicate the miss...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 07-28-2020 at 10:59 AM.. |
Well yesterday was as wet as it can get when i left work before midnight and the car ran perfectly so now i'm even more bafled...Also i have diagnosed that the misfire goes away when i "wake up" the engine by accelerating hard over 4k rpm. It would probably go away instantly after start if i'd accelerate, but don't wanna stress the cold engine. And the worst misfire happens in cylinders 6 and 2 (the old plugs in those weren't only carbon fouled, but also a bit oily). |
The plug you have to remove is Alu.plug not plastic.it is held in with a C clip on it`s end.The best how i do it is ,drill 2 little hole about 4mm between then use needle nose pliers and pull it out.Pretty safe stuff no worries.Once you have it check the fuel mix and adjust it,as it is on the manual instructions.
Still,if you want to duplicate the wet condition as i have suggested get a spray bottle with water and while the engine is running spray on each cyl..you see any miss right away... Ivan
no spray the water on each cylinder on top to try to duplicate the wet weather.Not so much only little moist will find the crack or something in your system..the plug looks like this..when removed..bottom of it
I think you may have an induction leak of some kind. Maybe some of the intake gaskets fell apart because of the intake being loose. You might want to pull the manifold and check the seal of said gaskets. You could try using a vacuum hose up to your ear and listen for a sucking sound around the intake at the heads.
i had a similar issue with fouled plugs that got progressively worse. Long story, short. It was a bad fuel damper. Simple test is to disconnect the vacuum line located on top of the damper and see if it has any fuel or smells like fuel (note: it should not have any fuel ). if it does, then you have a tear in the diaphram inside the damper and it is allowing unmetered fuel into your intake manifold. The DME is now trying to compensate for the extra fuel and your car is running bad.
Johan, do yourself a favor..do not start taking things apart until you know where the problem is...
friendly advice....;-) Ivan
After removing the afm & airbox assembly i noticed a hose that was a bit damaged. The hose led to the throttle body, no idea what it does. I put some high temp silicone glue to the broken hose as a temporary fix to see if it affects anything. Picture shows the damaged hose.
well you do as you do and want .i have my 911 for 24 years and i had never ever need to take off the throttle body;-))))let`s hope you got new o ring for it;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 08-03-2020 at 09:47 AM.. |
Anyway i think i got the car working, didn't want to post this too soon, but after testing the car for 3 days the misfiring is indeed gone. Not sure did the cleaning of throttle body (which i didn't get a new rubber o ring by the way, the old one seemed ok though), AFM or IACV fix it. Most probably it was the temporary high temp silicone sealant fix i did to the broken hose that goes to the throttle body. After that i had to adjust the motronic fuel quality switch back to position 0 from position 3 because the car was running lean and missfiring very badly. After the motronic adjustment 0 misfires, bit of backfiring after hard pulls though. The vacuum line from the fuel pressure damper to the fuel pressure regulator was also disconnected from the fuel pressure regulator side (left side of the engine compartment) which could have maybe affected the engine? Noticed it while inspecting the vacuum line for fuel deposits which it didn't luckily have. Thanks for all the feedback and help! Hopefully my joy isn't too premature. Will still get the CO mix adjusted shortly because it has been neglected for so long. |
Brew Master
I wouldn't touch the mixture screw until you're sure your vacuum lines and everything else are up to snuff. Hoses that look cracked should be replaced. Switches should be checked for proper operation. IACV should be cleaned. Manifold boots checked for cracks. What I'm getting at is, make sure things are right before messing with that screw.
I'm going to disagree with proporsche on setting the base idle mixture being yearly maintenance. If your hoses are in good shape, your fuel pressure is right, your injectors are clean and your AFM is working properly, there shouldn't be a need to mess with that screw which is why it's capped in the first place. People pull the cap to mess with the mixture typically to overcome another issue with the car.
Nick Last edited by cabmandone; 08-06-2020 at 09:09 AM.. |
