KOH KOH is offline
'87 Carrera valve adjustment problem
This is my first attempt at doing a valve adjustment on my '87 Carrera. The A/C pulley will not allow me to get any kind of wrench onto the bolt in order to turn over the engine (see pics).
I also tried turning it over with a wrench on the alternator as shown in Wayne's book, but that only slips the belt.
How do you turn over an engine with this A/C pulley? The width of the ruler in the second picture is not quite 3/4".
Thanks for any help or suggestions.
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C
Old 07-25-2020, 06:35 AM
Press in firmly on the right side of the belt, just below the top pulley, as you turn the top pulley clockwise.
206 637 4071
Old 07-25-2020, 06:46 AM
KOH KOH is offline
I'll try that. Thanks, John.
Old 07-25-2020, 06:53 AM
I use a large pair of channel locks to turn the crank pulley.
Old 07-25-2020, 07:35 AM
I know that JW does not recommend removing the spark plugs during valve adjustment but ... I always do.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-25-2020, 07:41 AM
MBAtarga's Avatar
Use the wrench in the tool kit on the top pulley nut while pressing against the belt as John Walker suggests. Please do NOT use a crescent or other slip joint pliers.
Mark
'83 SC Targa - since 5/5/2001
Old 07-25-2020, 07:46 AM
If the above was not clear, you are squeezing the belt so it does not slip on the pulley while you are turning the engine with alternator pulley.
Old 07-25-2020, 08:18 AM
KOH KOH is offline
Guys, thank you all for your help. I am able to turn the crank by putting pressure on the belt while my son turns the alternator nut.
Old 07-25-2020, 09:00 AM
Left hand turns the nut, right presses the belt. One man job.
206 637 4071
Old 07-25-2020, 09:32 AM
proporsche's Avatar
yelcab. removing the spark plugs you are asking for a wrong valve adjustment.Little carbon can fell on top the valve seat and it`ll screw your adjustment settings..bad idea..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-25-2020, 09:53 AM
Formerly known as Syzygy
Canada Kev's Avatar
Yeah, probably not the best practice. And there's no real need to remove plugs as the engine is easy to turn over with the plugs in.
Kevin
Old 07-25-2020, 01:45 PM
Ivan
yes, I got it. I understand the concept. It's just never happened to me.
Old 07-25-2020, 05:00 PM
proporsche's Avatar
yelcab.... there is always the 1st time, my luckily happened in 1987 on 930 right hand side top it is a bi...h to get ....so,i learned;-)
Ivan
Old 07-26-2020, 01:14 AM
