thrown_hammer's Avatar
Question DME info please
Heres all the info from my claimed Euro DME box. I have a 1986 US spec 3.2 completely stock with this DME box.
0 261 200 078
911.618.111.12
typ911 mws-01
Anyone know which box this is? It is supposed to be a Euro DME but I don't know which one.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 04-17-2003, 06:59 AM
Hi Shawn:
Just went through my notes and I believe you have a standard North American DME from 87 on. Was the box previously opened? If so, who knows what chip you have.
Tim
Old 04-17-2003, 08:48 AM
I didn't open the box. So I don't know about the chip.
1975 911S (sold)
Old 04-17-2003, 09:05 AM
Something doesn't quite match..
From the factory manuals, the 1984 thru 86 boxes are:
ROW Carrera....911.618.111.04 (Bosch 0 261 200 051)
911 Carrera for Sweden, Switzerland, Australia, New Zealand, Hong Kong .... 911.618.111.06 ( Bosch 0 261 200 052)
911 Carrera for UK, France Luxemburg, Spain, Portugal, Greece,Saudi Arabia....911.618.111.07 ( Bosch 0 261 200 051)
911 Carrera for USA, Canada, Japan...911.618.111.05 ( Bosch 0 261 200 050)
for 87 onwards in the 3.2 series....
hi-compression engines worldwide..911.618.111.18 ( 0 261 200 078)
Cars with M240( "inferior fuel"...not USA), and DME switch to position 4
911.618.111.19 ( 0 261 200 078)
USA, Calif, Japan, Canada, Austria, Swtzerland, Australia, with M 298 ( unleaded fuel, manual trans?)..... 911.618.111.20 ( 0 261 200 082)
Hi-compression engines worldwide with M 637 ( sport group)....911.618.111.15 ( 0 261 200 084)
USA, Calif, Japan, Canada, Austria, Switzerland, australia, with M 637.....911.618.111.16 ( 0 261 200 085)
Cars with M240 and M 637/ Pc board switch at position 4.....911.618.111.17 ( 0 261 200 084)
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-20-2003, 05:07 PM
Could a dealership be of any help? The car runs great except for an annoying idle hang up.(I have to blip the throttle to knock the idle form 1200RPM to 1000) So I guess it's not something to lose sleep over, just curios.
1975 911S (sold)
Old 04-21-2003, 04:43 AM
Notice that you have a Bosch "078" box. Notice also that this Bosch number cross-references to two or more Porsche part numbers...indicating the box's architecture is the same...but some small thing may be different to require a different Porsche number...maybe the coding of the chip.
Others on this board may be able to identify the "111.12" Porsche part number original application ( it's certainly not from the 84-89 Carrera series... as indicated by my previous post related to the factory manual). So a confirmation of the OEM application for this number, and maybe opening up the box to see the chip label...will get you most of the way there.
--Wil Ferch
Wil Ferch
Old 04-21-2003, 08:43 AM
Sorry for the previous miss-information.
I included the information Wil posted (Thanks Wil!). Some numbers contained here are still a little suspect, like the dates for the "05" ROW box. If anyone sees any errors or has additional information, let me know and I'll add it. It would be nice to have a summary list that is reasonably accurate.
Tim
Old 04-22-2003, 10:38 AM
So I have an '86ROW DME box. Would this cause any kind of problem with a US spec '86 3.2 engine??
1975 911S (sold)
Old 04-22-2003, 11:04 AM
I have a DME box no. 911.618.111.13 (Bosch no. 0 261 200 078), TYP 911 MWS-01 on my car. I presume that it is a ROW box since I sourced it here in the UK - I built my car from many different second hand parts from breakers, so I am not sure of the origin or year of car that this box actually came from, but my '84 rngine runs well on it. Chip inside looks to be original, is 24 pin removable, and has a silver label with the number 1267355211 on it.
I haven't seen any reference to these particular part nos. in any previous correspondence on DME's on this board, so maybe this is another piece of information for those of you collating DME information. Can any other UK Carrera owner confirm these numbers also?
Keith
Old 04-22-2003, 01:37 PM
Zyvek's Avatar
FWIW I have DME box # 911.618.111.12 (BOSCH 0 261 200 078, TYPE 911 MWS-01) in my stock '86 Euro Carrera with P/N 1267355211 on the EPROM. I'm not sure what size the EPROM is but I'll peel back the sticker this weekend and follow up. My car does have the 930/20 engine so I assume most of the USA chips out there wont work in my car (with this box and 930/20 engine) due to the higher compression ratio....any thoughts on this?
-Armand
'86 Euro Carrera (for sale)
'11 K1300s / '10 EX250 / '08 Ducati 1098
'05 Xterra
Old 05-02-2003, 11:03 PM
Zyvek's Avatar
Chip 1267355211 is a 2732A, (4K) so this DME box # 911.618.111.12 must be one of the later types...
-Armand
'05 Xterra
Old 05-03-2003, 07:38 PM
THECARREAPER's Avatar
glad i found this thread ( finally)
i have a German sold high compression 1984 Carrera.
my DME numbers are as follows:
* 0 261 200 051 078 *
* 911 618 111 00 *
vin WPOZZZ91ES101491
car was Federalized when it was brought in, complete with a cat ( now has a bypass pipe)
i want to see if i already have a socket, or if my DME will require soldering to install a chip.
not sure if i am going with Autothority or Steve Wong chip .... ???
anyway to tell by part number if this should have a socket already for the later style chips? i have a friend that has offered me a chip for a really good price...
sorry for the bonehead questions, i am still learning 911's !
Old 02-12-2007, 03:08 AM
its out... will take apart and see what numbers are on the chip.
i wonder what the "078" means off by itself?
perhaps a revision of the hardware or code?
Old 02-12-2007, 01:40 PM
