relay identification
hi all 1988 911 convertible top that i am having a problem getting power to the control top power unit. So its a fuse wiring issue
checked the fuse, all is good. then the red wire from the fuse that goes into this relay that is located under the fuse box. I have enclosed pictures . There is also a white wire as you can see that goes to nowhere. so i do not know if the loose wire causes the control top issues or its the relay or something else.
Finally the white wire leaving the relay go where?
can someone tell me the part number or how to test this relay or have a wiring diagram for this issue thanks, or some advice. its seems to bee the relay that is screwed in below the fuse box
thanks
Rich
Old 07-31-2020, 10:27 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relay.
That relay does not look factory to me.
Also, appears to be associated with your lights.
I have the factory manual.
I'll have a look.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-31-2020, 12:13 PM
Red Line Service
Marc Bixen's Avatar
Cab top problems, many times, are broken solder joints in the ECU. 89 3.2 ECU, should be under the passenger floor board.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 07-31-2020, 01:47 PM
Had the ecu tested and it passed
In using the power top diagnosis located in this forum I am not getting power to terminal 30 on the first plug
So it’s a wiring issue. So I am trying to trace the wiring from the fuse to the ecu under the footwell. First stop was this relay
Thanks targa for looking I could not find it on the schematic at all
Old 07-31-2020, 06:33 PM
On a typical relay 30 goes to main power source.
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 08-01-2020, 11:20 AM
It's not there.
Have look at the headlight circuit diagram and pm me as needed.
Gerry
1986 911 Targa.
Only in L.A.:
Old 08-01-2020, 11:33 AM
