-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Anyone with KW V3 struts/shocks? (http://forums.pelicanparts.com/showthread.php?t=1069640)
Bli8 08-08-2020 01:08 PM
KW makes a replacement struct w/ adjustable shocks for our cars but I can't find any review or user experience from anywhere. A search using the word "kw" came back lots of posts but nothing on the V3 shocks. I'm looking for new struts as I sent mine off to a shop for raising of the spindle, then never heard back from them so chances are I'm out of a pair of struts and may as well see what other aftermarket struts are out there.
They look good too
https://www.kwsuspensions.com/media/...001_640_56.jpg
Jonny042 08-08-2020 01:33 PM
I have them and they are awesome. They have versions with the spindles raised 19mm, which is worth having IMO. They are a very tight fit for 15" Fuchs but doable.
The Pelican Forum search is horrible. Plain and simple. Use google, by putting this in the google search field:
site:forums.pelicanparts.com/porsche-911-technical-forum/ kw v3
It will do wonders.
Bli8 08-08-2020 01:40 PM
It will do wonders.
You are correct about the forum's search function as I just found many posts using other search methods.
I'm sure they tighten up the handling for sporty or track use, but do they also ride better in soft settings than OEM or Bilstein B6's?
Steve W 08-08-2020 08:32 PM
They are amazing. The adjustment range is way beyond what anyone could use. From super plush softer than Boge to teeth buzzing stiff. Even if you had the stiffest torsion bars, you'd still set them in the middle. They are noticeably shorter and combined with the raised spindle option you could lower the car way below Euro height and you'd still not hit the bump stops. If you combine them with the Rebel Racing RSR bushings, even if you install stiffer torsion bars such as 23/31s or 24/33s, the car will ride even smoother and more comfortable on the street than a stock suspension because of the elimination of the factory bushing friction, and the digressive valves and two way adjustability, you can match any spring rate and set to ride as you want.
You can spend a bunch of money on Bilsteins raising spindles, shortening them, custom valving, and you'd still not have what the KWs offer you. I like them so much I'd sell the modified Bilstein set on my other car to replace them. Anyways you can see them on my '86 if you're going to be running the POC San Pedro autocross tomorrow.
And regarding Rebel Racing, don't worry. Clint is slow because his parts and services are in demand more than he should handle but he will deliver.
Arlo911 08-08-2020 11:07 PM
I also run a set of V3's on my SC and have had KW suspension on 3 different BMW's. They ride a lot better than stock valved Bilsteins.
There are some people that question the strength of the shafts, they are not an upside down design as the Bilsteins, but if you want upside down design there is also the Clubsport version. Not cheap but they come with camberplates, are available with or without coilsprings, and raised spindles are also available.
Another downside might be the adjustability, best to let someone experienced set them up or keep track of the amount of "clicks" you adjust so you can revert back to standard settings if you need to.
famoroso 08-09-2020 08:35 AM
I have them on my '87 491 coupe, in conjunction with new rubber bushings and Eibach Anti-roll-kit. They are amazing!
I agree with everything that Steve Wong says above.
Without question, I'd install them again.
Raised spindle, double adjustable, digressively valved KW V3s, Eibach anti-roll kit, Elephant rubber bushings, ERP 935 spherical tie rod ends, etc, all assembled and dialed-in by Jae Lee. Taut and confidence inspiring, yet compliant enough (with compression and rebound both set about 1/3 of the way up from full "soft") so as not to offend. It's magical. Impressive, considering the 50+ year old suspension design...
http://forums.pelicanparts.com/uploa...1596990497.jpg
http://forums.pelicanparts.com/uploa...1592578348.jpg
http://forums.pelicanparts.com/uploa...1592576094.jpg
Jae Lee / Mirage did a similar setup on my '88 491 cab, but with Bilstein B6 all around. That system is also very good and although it's a bit apples / oranges (different vehicle with a different purpose), I assure you that the KW setup is not only a different ballgame, but a different sport altogether.
Any G body I build going forward will have KW V3s. I've spent time talking to the guys at Makellos Classics and they are huge fans too.
Fly911 08-09-2020 08:51 AM
Question to Steve W and all suspension gurus:
What gives the best overall handling (road and track)?
With the KW V3's nearly unlimited adjustability, and limited (if any) adjustability on the torsion bars, and with adjustable sway bars, would a soft torsion bar set up give the best handling? Softer suspension absorbs bumps better, making better tire contact and less upset movement of the car.
Will a soft suspension set up in combination with a stiffer shocks and sway bar settings, be a smart move? Would a stiffer shock and sway bar set up compensate for the softer torsion bar set up on track and aggressive driving?
What is the ideal correlation between spring rates (torsion bars or coil overs) and the shocks compression and rebound rates?
And for limiting body roll, what would the best set up be, spring rates or sway bars?
My point here is that the spring rates (stiffness) on T-bars and coil springs are typically not adjustable, and shocks and sway bars are.
Anyone...???
Bli8 08-09-2020 10:54 AM
I AM be at the autox now in the green RS. Will come looking for you after I finish eating my Burning Buns burger.
CBA 03-03-2022 10:03 AM
Bringing up an older post. Can these be installed on pre '74 cars? I'm not 100% sure what the differences are on the F Body cars versus the G Body's suspension wise.
Thank you
H-viken 03-04-2022 10:50 PM
Thank you
Shouldn’t be an issue for 69-73 cars
Jonny042 03-05-2022 05:27 AM
They work on any torsion bar 911.
I'd def. recommend going for the 19mm raised version, but be aware they will be a tight fit with 15" wheels. Totally worth it. Even with the 19mm raised spindles I had to use 42mm of shims on my bumpsteer adjustment:
Originally Posted by Jonny042 (Post 11269312)
Just finished doing bumpsteer measurement and adjustment on the front end - been putting this off for a while but finally dug in.
What actually triggered the whole exercise is that I did a slight ride height adjustment in front, raising the ride height maybe 3/4". I measured the toe before and after and couldn't believe my eyes - I gained 3/16" of toe-in just raising the front that little bit!!
After finally settling on a front ride height of 151mm (measured the factory way but accounting for the 19mm raised spindles) I marked a line on the front bumper and backed the ride height adjustment so I could raise and lower the car around ride hieght and measure the toe changes.
I played with some pretty coarse adjustments and finally honed into doing 2mm of shim changes at a time. All I can say is WOW. A much smaller increment than I thought can make a measurable difference!!!
http://forums.pelicanparts.com/uploa...1616455568.jpg
The picture above shows all the shims in place during one of the "extreme" tests. Ultimately I ended up with 42mm being the magic number for total spacer height. My final check was to run the suspension through 2-1/2" of travel (1-1/4 above and below ride height) and have no measurable difference in toe.
CBA 03-05-2022 01:36 PM
Thanks guys. Have them on my ‘90 and figure why not on my ‘73.
mar2mar 03-05-2022 03:06 PM
So with a bit of modifications, you can use the G-body version KW V3 with 19mm raised spindles on an F-body 911 w/ 15” wheels?
On their website I didn’t see a KW V3 for F-body with raised spindles.
CBA 03-06-2022 07:20 AM
Jonny042 has them installed on his backdate. You can read through his detailed build on his car. Yes they will go on a F-Bodied car. I was pretty sure but wanted confirmation and it has been confirmed.
mar2mar 03-06-2022 12:02 PM
Thanks CBA, This is on my wish list for my 70 911.
Jonny042 03-06-2022 02:55 PM
Wheels are the only consideration - I had to get pretty creative with a grinder in a few spots on the lower control arm to make it work with my 15" Fuchs. But totally worth it. And not a big deal.
In my opinion 90% of 911s out there are running on the bumpstops and raising the spindles can help gain much needed suspension travel.
I was really surprised by how much correction the bumpsteer needed on the car, see the long winded post above).
The combination of the KWs, raised spindles, and bumpsteer correction, mean the car is an absolute pleasure to drive. Like it was meant to be!
Jonny042 03-06-2022 03:08 PM
Further to above, from page 40 of the Project Heavy Metal build thread. I removed the hard plastic spacer above the bumpstop to gain even more travel out of the KW's (greater than the stock Bilsteins to begin with, but now 15mm more, plus the lowered spindles).
Originally Posted by Jonny042 (Post 10632890)
http://forums.pelicanparts.com/uploa...1571834933.jpg
Without actually handling the bumpstops tat came with the V3 it's hard to tell how tall their effective height is, due to the integral dust shield. The top of the green tape represents the bottom of the bumpstop.
http://forums.pelicanparts.com/uploa...1571835265.jpg
There is a hard plastic spacer above the bumpstop, easily removed, to provide some much needed suspension travel:
http://forums.pelicanparts.com/uploa...1571835621.jpg
http://forums.pelicanparts.com/uploa...1571835715.jpg
Jonny042 03-06-2022 03:20 PM
As you can see the car sits relatively low but even at this altitude it has plenty of suspension travel. Our roads are not great, it doesn't care.
Originally Posted by Jonny042 (Post 11448324)
Once in a while a picture captures the subject perfectly - this shot does just that, gives exactly the right perspective that truly is a representation of what the car looks like in the flesh:
http://forums.pelicanparts.com/uploa...1630852113.jpg
It's got a great rear, too!!!
Jonny042 03-06-2022 03:21 PM
Also from the thread - when the car was set too low:
Originally Posted by Jonny042 (Post 11142566)
I'm a huge fan of the KW's, they will be a part of any future builds I do. I can't say I've fiddled extensively with the damping, beyond chasing my tail a bit..... when I put the CN36's and Fuchs on the car looked a bit funny, too low in the rear and high in the front. Of course the 10 minute solution was to lower the front:
http://forums.pelicanparts.com/uploa...1607996709.jpg
This setup left with only about 5/8" of free travel in front before hitting the bumpstops. Impressively enough I was able to tune out the resulting bounciness with the shocks, but it created some strange dynamic behavior.
Once the light went off and I actually checked the free travel I went to the trouble of raising both ends of the car and re-tuning the shocks based on a few drives on bumpy roads. I wouldn't say I've sharpened this to a very fine point but am a believer!
With the current setup (rubber stock bushings all around, SC sways front and rear, and 19mm/25mm torsion bars) the car absolutely devours large bumps and potholes and has great chassis control. The damping characteristics of the KW's are miles ahead of the bilsteins I have on the Rot Rod. In that respect the adjustable damping is not the only advantage.
Are they expensive? Hell yes, but a good value IMO. There are just so many possibilities and variables that you can choose with the 911, different weights and setups and spring rates, having the ability to truly dial the suspension in to your combination is a huge, rather than having to deal with a one-size fits all setup.
Tremelune 03-08-2022 10:12 AM
This just cost me thousands.
Jeff Alton 03-08-2022 09:47 PM
Big fan of KW, however far bigger fan of MCS. Check out their products for this application. A step above and beyond.
Also, with the level of shear load shown in the pics obtaining bump steer correction I would consider gusseting that load to the arm....
Cheers
CBA 03-09-2022 12:49 AM
[QUOTE=Jeff Alton;11630148]Big fan of KW, however far bigger fan of MCS. Check out their products for this application. A step above and beyond.
Cheers[/QUOTE
Just checked those out and looks like a sweet setup…. looks like about 2x’s the price of KW’s. Does that sound about right?
donbecker1234 03-09-2022 03:46 AM
For those that are more visual, here is a link to a chart I put together comparing the stock struts, Elephant's modified struts and the KW's:
http://forums.pelicanparts.com/porsche-911-technical-forum/1081446-balancing-torsion-bars-front-rear.html#post11151989
H-viken 07-17-2022 09:10 AM
I just ordered a set of KWs. My car has 19/26 torsion bars and weighs ca 1,000kg. Any thoughts on good starting points for the shocks for spirited canyon driving (in terms of “clicks”)? Rather it is on the softer side to start with
H-viken 09-11-2022 04:14 AM
Thank you
Johnny, do the KWs take the half moon ball joints or do they require the ones with a wedge?
Jonny042 09-11-2022 05:09 AM
Wedge.
I actually didn't know there was any other kind!
Dieter9 03-29-2024 01:03 PM
Do i need bump steer kit when fitting these ?
Thx
PeteKz 03-29-2024 04:05 PM
Dieter, it depends on what ride height you want. If you plan to lower the front of the car, order struts with raised spindles for the amount of drop you want, then you won't need to mess with bump steer correction. The most popular spindle raise is 3/4"/19mm. You can still run 15" wheels, but 16" will give more clearance to the brakes and ball joint.
famoroso 03-30-2024 08:12 PM
GREAT reading regarding bump steer (the phenomenon and process to address it, not just the rack or tie-rod end spacers)...
http://forums.pelicanparts.com/porsche-911-technical-forum/1116600-19mm-raised-front-spindles-adjustable-bump-steer-no.html
There's A LOT to process / digest in there.
When the right hardware is combined with the right bump steer procedure / corner balance / alignment, the results can be really compelling.
My Gemini Blue '87, w/ raised spindle KWV3s, that has been bump steered, corner balanced and performance aligned is at another level in comparison to my other cars. My newly acquired GP White '87 has fresh bushings and Bilstein HDs (green) and drives pretty nicely, but I am very much looking forward to how much better it will drive after bump steer procedure + corner balance + alignment. Should be a reasonably good A/B test vs. KWs too.
Steve W 03-30-2024 09:25 PM
I have the 19mm raised spindle version and on my car which I think is about 3/4" or so lower than 'euro ride height' I did bump steer measurements and adjustment and came to the exact same number of shims as Jonny at 42mm with a Rebel racing bump steer kit. But I did this by spacing the steering rack up about 11mm, and used 31mm of shims at the tie rod end. But note that this 31mm is measured with using a spherical rod end as you see with the bump steer kits, and is not the same height as the factory tie rod end which is tapered threaded rod end is longer/taller than a spherical end by I'm guessing about 15mm. So going with the same setup as above, and just adding rack spacers, and not changing the tie rod ends to a bump steer kit, you'd only be maybe about 15 more mm from a zero bump steer curve.
anil999 04-04-2024 10:11 AM
I've recently purchased a set of KW shocks with the 19mm raised spindles.
Note that the shock bodies now have a tough black epoxy coating as opposed to the previous yellow zinc plating.
A couple of questions regarding the front struts for those that have also fitted them recently:
1) Should I keep the top 10mm spacer above the bump stop or remove it? I wasn't sure if this spacer was primarily for the North American market.
2) The hub mounting spindle currently has a black electroplated finish. Does this need to be removed back to bare metal or can I go ahead and mount the hub/bearing assembly without any further action?
http://forums.pelicanparts.com/uploa...1712253967.jpg
Dieter9 04-04-2024 10:12 AM
Online someone states you still need a bump steer kit even with the dropped spindels ?
H-viken 04-04-2024 11:14 AM
Double-check but believe the instruction that comes with the shocks says to remove it
Bibaboi 04-04-2024 12:55 PM
I did that and it made a huge impact on how my car handled, especially while turning and going over uneven surfaces. Now i can rest one hand on the steering while driving and steering feels lighter as well.
nickelplated5s 04-05-2024 07:47 AM
Grasshoppers, there's another way to do this. Figure out what 'throw' you need for the shock. Source it. I've got externally adjustable Koni's. Shop was supposed to get me a part # when it was in but didn't. Here's the key, you have to shim inside the strut for the shorter throw shock. My SWB is 24" ground to fender lip in the front.
LukasM 02-27-2025 01:44 PM
Very good input Jonny!
I wonder if KW is aware of this, and why they have not incorporated a parallel lower support so the tie rod bolt is in double shear, similar to what Elephant is doing with the Bilstein struts? Would be very cheap to
https://www.elephantracing.com/wp-co...ngle-large.jpg
At least with the new black version of the struts you could add one yourself and then paint repaint them in black, easier than it was with the gold zinc plating.
What did you end up doing about those two things?
Cheers,
Lukas
DennisMenace 08-05-2025 07:27 AM
Hi Jonny042. Currently in the process of acquiring a KW V3 for my 911 3.2 on 7/8 15 inch Fuchs as well. Would love to fit the raised spindles strut on my car. Would you mind sharing any details how you were able to use a grinder to make the strut fit with the 15 inch? Thanks and best, Dennis
PeteKz 08-05-2025 10:27 AM
Let me repost a question I put on a parallel thread:
For anyone who has tried this or knows: If one starts with a stock strut and raises the spindle 19mm, can you bend the steering arm down 19mm to correct the bump steer? It seems to me that should work, and avoid the necessity of adding the lower brackets and Heim joints.
DennisMenace 08-15-2025 01:47 PM
Which torsion bars are you guys running with the KW V3?
Bill Verburg 08-15-2025 04:33 PM
Here's a survey of t-bar effects
http://forums.pelicanparts.com/uploa...1755304373.jpg
