Does this look right?
Hi guys,
I'm rebuilding my gear shifter and when I reinstalled the mounting plate, I noticed that the two "tabs" on the plate looked crooked... At the moment the car is still pretty much a bare shell so I can't check the gears by shifting into gear. I would really like to know if I should correct the angle of these "tabs" or if this is just how it's supposed to be? I know for a fact that all of the original bushings had to be replaced so my theory is that maybe the previous owner modified te mounting plate to correct for worn bushings... ![]()
1973 2.4 MFI bone-stock 911T Last edited by D@vid; 09-29-2020 at 10:28 AM.. |
Bueller... Bueller...
Uncertifiable!!!
Supposed to be vertical but no biggy. On the assumption that the shifting is good I would think that you can achieve the same thing by adjusting the hook on the shifter if it’s visually bothersome.
Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Thanks Johan,
The thing is, I'm rebuilding the car so I will be re-aligning everything. I'll correct the angle now the shifter is out of the car.
1973 2.4 MFI bone-stock 911T |
If it ain't broke...
How many minutes would it take to pull the shifter later? |
That is correct. Push the shift lever over against the right side and u will see the stick is at an angle that lines up with tabs.
thanks for your input guys
