Zenith carb linkage
Hi All! I'm in the process of putting a 71T together. I bought it in boxes so I stumble upon having the wrong parts all the time.
Putting on the intake manifolds, the brackets for the lever that goes between the manifolds is not lining up.
The manifolds got the same number but the left is setup with the additional bracket in the front.
Do I have the wrong brackets? I suppose the lever between the manifolds should be parallell?
Can anyone give some input, images and if there are different brackets.
Thanks,
Jörgen Forssling
Gothenburg
SWEDEN
Old 10-10-2020, 07:12 AM
Looks just like mine, think you are fine. Linkage does not run perpendicular.
Old 10-10-2020, 04:08 PM
porschetub's Avatar
The angle of the linkage is dictated by cylinder offset,make sure you check/replace linkage ball cups,most of mine were rather worn on my motor,it makes a real difference when setting up carbs.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 10-10-2020, 05:12 PM
Thank you!
Jörgen
Old 10-11-2020, 12:14 AM
proporsche's Avatar
this
"It makes a real difference when setting up carbs"
absolutely yes 100%
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-11-2020, 06:55 AM
Originally Posted by proporsche View Post
this
absolutely yes 100%
Ivan
Thanks guys, I'm replacing them all!
//J
Old 10-11-2020, 07:30 AM
