Racer
Where are your headers made? In your shop in Huntsville? By a job shop elsewhere in the U.S.A.? Overseas?
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Brian,
Thank you for designing and producing these awesome heat exchangers. At one point I recall there was discussion of a ‘flat bottom’ evolution of the heat boxes. Is that a possible option on these? Regards Steve |
Yes the 1.63" flat bottom exchangers are finished and I just completed installation on several sets of headers that went out yesterday. 1.75" is next and will be done shortly. These will have a service panel same as the RSR version.
I hope those flat bottom heat exchangers are going on the set you’re sending me for my 964 RS build with Al in Seattle! I could use the clearance on the hills around here.
Does switching between the quiet and loud modes change the engine tune at all?
I'd be worried about that. I'm exploring using a GT3 RS muffler with my engine build and we'll need to have two separate engine maps in the MOTEC engine management system to optimize both sides of the muffler.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
2 Motec setups
You do not need two setups with your Motec.With the new system with adaptive it will not matter.That is why you pay the money.Ciao Fred
Adaptive and active are two different things as far as I know. The shop I'm working with is "the best" when it comes to MOTEC, modifying big bore Porsche motors, etc. Their dyno expert tells me for sure MOTEC needs 2 different programs....one for the quiet restrictive side, another for the loud free flowing side. This only makes sense to me.
Yes the revised exchanger design rolled out quickly to take advantage of increased ground clearance for the 1.63" headers. I'm finishing up the patterns now for the 1.75" units to drop them off at the sheet metal shop this week.
The valves open when the engine is under load. I wouldn't think different programs would be needed if the parameters include engine load. The closed route is not restrictive as it meets the needs of the engine under the conditions required to keep the valves closed.
My tuner tells me that without heavy load, the exhaust needs will be moderate and can be handled by the quiet pipes. The engine will not notice. More flow will be wasted at low load. Under heavier load, the valves will activate, opening the exhaust flow just at the time the engine needs it. |
Yep.
I'll be over at their shop next month with my car and will talk further with them at that time. That said, I've already pretty much decided to only have the quiet side hooked up...blanking over the sport side of the muffler. Even the quiet side is loud enough for daily driving and will flow more than enough for my engine.
Subs
Anyone have a line on one of these mufflers? If so, I'm interested.
Also, anyone have the part numbers handy? I assume there are at least four... 997 GT3 997 GT3 RS 991 GT3 991 GT3 RS However, there's probably a ton more part numbers given .1 vs .2 for both series and the part number supercession game.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
The GT3 muffler makes great power for the larger (3.6, 3.8) air-cooled engines. And more importantly more me is the sound. I just really like how a GT3 muffler sounds when hooked up to a large displacement air-cooled engine. They look great on an early car also.
IMO it's the best sounding muffler for air cooled 911's I've ever tried. However, for bigger motors like the 3.6 - it's not the most effective. Sound clip here: https://www.instagram.com/p/B-FDFtVlVtZ/ |
I am in Brian's queue for a set of headers and his Active Exhaust, Split Secondary System for a GT3 box. Unfortunately, I still haven't found the GT3 box. I am going to run his 2 in / 1 out muffler in the interim, but the search is on for a GT3 box! Anyone have a line on a 997 titanium unit? If so, please let me know. Why do you say it isn't as effective on bigger motors? GT3s have bigger motors and the rear box is one of three mufflers in that system?
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 02-16-2021 at 06:11 AM.. |
It's very effective on the big motors, but just not THE most effective. We did back-to-back tests with GT3 and Dynomax 17231 on a 3.6, and the Dynomax has better top end flow. |
https://rennlist.com/forums/market/1228561
Always learning. www.aircooledporsches.com.au |
which pipes are you using on the GT3 muffler with the 3.6? Here is how we had the muffler plumbed on one we did late December. No valves but wish we did. The sound is actually pretty glorious, but we had a bit of drone between 2000 and 3000... above 3k it was magic, but loud. On my 3.0 with a GT3 muff, I only use the smaller ports.. and use a 2.25inch diameter pipe.. it's perfect. At higher rpm, it fricking screams!
