Bleeding clutch slave cylinder--problems
I bled the clutch slave cylinder on my 89 Porsche Carrera. No (or very few) bubbles came out, but now I have a problem.
I can put the car in gear with the shift lever, but in any gear (not 1-5 or Reverse), I am able to actually turn the rear rotors by hand. The clutch doesn't seem to connect the transmission and motor anymore. What did I do wrong?
I'd be grateful for any anybody help on this.
Thank you.
Old 12-20-2020, 10:07 AM
Normal. Drive it.
206 637 4071
Old 12-20-2020, 10:16 AM
I have the car on jack stands, and the wheels don't turn with the car in gear and motor running.
Old 12-20-2020, 10:49 AM
Did you look at both wheels? Differentials work in mysterious ways.
206 637 4071
Old 12-20-2020, 04:16 PM
rokemester's Avatar
There are certain jobs like bleeding the clutch slave that you do and then have to completely relearn the next time you do it, except for people like John! I found the little slave clutch bleed tool that a Pelican developed to be quite handy!
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 12-20-2020, 04:27 PM
spedrcr's Avatar
It's all about the right tool for the job. Makes all the difference. I made my own for my G50 slave bleed job.
Old 12-20-2020, 05:11 PM
Yes. When I am under the car and turn one wheel, the other wheel turns in the same direction with the motor in gear
Old 12-21-2020, 09:07 AM
Tags
clutch , slave cylinder
