Reiver
I put a large round magnet on the oil tank to garner anything...and remove it when draining the oil....the small sump bolt has the magnet on it. I also regularly cut open oil filters.....
De Oppresso Liber Strength and Honor 5th Legion |
My outies have magnets.
My mistake, I should have been more specific. I'm asking about a 1987 3.2.
Maverick Region PCA, Fort Worth/Dallas area 1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249 1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD 1982 924 White, SOLD long ago 1966 912 Red, SOLD, totaled a week later by its new owner |
On my '87, I believe it's M22x1.5 in the tank, and M20x1.5 in the sump.
Still here
The factory plug installed properly should last a lifetime of oil changes, that’s only way sttuttgart would have designed it ! Can’t say the same for the Fumoto. Last edited by pmax; 01-01-2021 at 01:46 PM.. |
Reiver
Lol...like the exploding airbox, Carrera valve guides, head studs...water cooled scored cylinders, IMS bearing.....but hey, they got that drain bolt down just right!
I've had fumoto valves on both of my cars for the last 15-20 years.
Still waiting for them to break. In the meantime...no gushers of oil when changing and much easier to clean up.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 01-01-2021 at 02:08 PM.. |
Still here
I wouldn't install any brass plug into the case. The tank plug is a piece of cake.
Looks like there's a "rubber" gasket instead of the factory Al washer. Does that need to be replaced every oil change ? Last edited by pmax; 01-01-2021 at 04:11 PM.. |
Of course not... The valve is not removed for oil changes; that's the whole point ;-)
Reiver
Go with whatever route you are comfortable with...Fumoto has been on the market for decades without issues.
I've used one for years now...if it scares you don't use it.
Our drain plugs are 22mm -1.5 ... well, for a 3.0 SC engine ... correct?
Jason
'79 911SC Targa |
Is this the part # for it? FD14-4002-18-06
^^^ With your thumb?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
if the Fumoto comes with a rubber washer, has anyone thought about ditching that rubber washer and replace it with the Porsche factory aluminum washer? Would doing that be a plus or minus, what do you think?
Another thing I like is when I take the oil to the recycle center it is already in a container that can be safely transported. Edit: Oops. Old thread. Last edited by Funracer; 12-15-2024 at 08:11 AM.. |
Hello all. If I wanted to use Stahlbus drain plugs on both the engine and the oil tank of my 964 C2, which ones should I buy? (Are they the same size?) M20 x 1.5 for both?
