Screw inserts for shift coupler cover
Redid the shift coupler on 83 and in removing the cover found one of the H shaped inserts that holds the cover screw was missing. Ive scoured the hosts web site, and anything else I can think of to find one or at least what they are called. I know the folded kind as clip nuts, speed nuts or blind nuts but these are a press in nut. Anyone know a part # or a link to them.
Old 12-30-2020, 02:29 PM
Reference “J” clips
Try McMaster web site
Bruce
Old 12-30-2020, 04:21 PM
Looked at those. Close but not quite. The ones on the tunnel are an H shape and press into the rectangular hole where the corners of the H keep it from going all the way through
Originally Posted by Flat6pac View Post
Reference “J” clips
Bruce
Old 12-30-2020, 05:23 PM
tholyoak's Avatar
Google 999.591.329.02 as some other vendors sell repos since Porsche has discontinued them
-Todd
1989 911 Targa
Old 12-30-2020, 05:39 PM
Still here
pmax's Avatar
Not sure they are even needed but aren't they just these ?
https://www.clipsandfasteners.com/u-clips-nuts-and-fasteners-s/115.htm
Everytime I mucked with it, I say to myself that's a lot of fussy screws for a dust cover.
Old 12-30-2020, 08:44 PM
911 carrera 3.2 (1985)
kees's Avatar
These ones?
Old 12-30-2020, 10:54 PM
I was looking for these for 26 years; I had one missing. Only this year did I get one from a breaker's yard. I bought 4, even though I needed only one and gave one away to someone who was also looking for years. They are called speed nuts and are NA, so your best bet is a breaker's yard. Or do a search for speed nut; someone called AlexJ found a source :
Prestole Cage Nuts
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 12-31-2020, 02:20 AM
kaputtrepariert's Avatar
These are available from pelican here: https://www.pelicanparts.com/More_Info/99959132901.htm?pn=999-591-329-01-OEM
tholyoak was close with the part number. Should be 99959132901
Old 12-31-2020, 05:10 AM
kees's Avatar
Old 12-31-2020, 06:50 AM
kees's Avatar
99959132901 and 99959132902 are the same. Only the colour differs (zinc vs yellow).
Old 12-31-2020, 06:56 AM
YES!!!!!!!!! Was about to post a pic.
Originally Posted by kees View Post
These ones?
Old 12-31-2020, 12:07 PM
Prestole Cage Nuts
Ive looked through McMasters entire catalogue of speed nuts, J nuts, z nuts, captive nuts and none push in. They all slide in.
Old 12-31-2020, 12:09 PM
Thanks to all that found the listing on pelican. I went through all the parts for my year but I guess since its universal it doesnt show it. Only need one but can put my OCD at ease.
Old 12-31-2020, 12:11 PM
Enginerd
TxGerman's Avatar
This is so timely and helpful. I am missing one too and was struggling to find a replacement. Thanks to the collective brain trust for coming through again!
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 01-05-2021, 01:08 PM
Been here a while
I’m searching for these for another project. Found these on Amazon, not sure if it’s the same size as what’s on my 911
https://www.amazon.com/dp/B07BNGNN22/ref=cm_sw_em_r_mt_dp_ht1-FbHVEPWNC
And then there’s this. https://www.pelicanparts.com/More_Info/99959132901.htm?pn=999-591-329-01-OEM&gclid=Cj0KCQiA6Or_BRC_ARIsAPzuer_4aQfovme2W5hCy77e-SqXu8KtFDnOJBokAOQ8Awm4tkP55xUw9JEaAptaEALw_wcB
looking for 1972 911t motor XR584, S/N 6121622
Old 01-10-2021, 11:33 AM
Originally Posted by blucille View Post
The pelican one is correct. The ones from Amazon may work but if you notice they are not "H" shaped and the length keeps them from falling through. The hole, in the shifter coupler cover is quite long. Youd need to measure.
Old 01-10-2021, 06:17 PM
