Baftub356's Avatar
Porsche Crest 83' 911sc Unknown Wire
I’m replacing my O2 sensor and came across this pair of wires that is taped at the ends and don’t know what it’s for. It follows up to the tray but is also attached to the rear deck lid hinge. The two wires are grey and brown as seen in the photo.
Thanks,
Old 12-31-2020, 12:30 PM
proporsche's Avatar
looks like you rear decklid light assembly wires..do you have one there?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-31-2020, 12:52 PM
proporsche's Avatar
this one
https://i.ebayimg.com/images/g/aCIAAOSw1~1f10AZ/s-l640.jpg
Old 12-31-2020, 12:55 PM
The grommet is the clue.
Bruce
Old 12-31-2020, 01:03 PM
Bruce
Not really sure the value of the grommet since the wire just clips to the center re-enforcing metal when its close to the light. Open to a lot of abuse.
Where does that circuit go? Mine wont come on. Socket and bulb are good. Tried with the door open, closed, lights on, lights off, parking light on. Cant get power to the bulb.
Old 12-31-2020, 02:19 PM
proporsche's Avatar
the wire goes through the rear decklid little hole and ands at the center where the light unit should be located...therefore the grommet is a sign...If you do not get power to it ...trace the wiring culprit via diagram...
Ivan
here a help for the Op and you..
Old 12-31-2020, 02:47 PM
ROW '78 911 Targa
timmy2's Avatar
The grey wire should plug into a short grey wire coming out of the driver side tail light 6 pin connector by the fuse panel.
It is only powered when the running lights are on.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-31-2020, 05:00 PM
Has anyone got a picture of where this engine lid light is positioned? I'd like to fit one if I knew where it went.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 01-01-2021, 07:33 AM
ROW '78 911 Targa
timmy2's Avatar
Does this help?
http://forums.pelicanparts.com/porsche-911-technical-forum/1046283-how-fix-engine-compartment-light-w-pics.html
Dennis
Old 01-01-2021, 07:52 AM
Mark Salvetti's Avatar
Not every deck lid has the metal tabs that the light screws to. Mine doesn't.
Mark
1979 911SC Targa
Old 01-01-2021, 08:54 AM
proporsche's Avatar
Mark S. in this case, if there is a original wire there will be the bracket to mount the light;-)
Ivan
Old 01-01-2021, 10:34 AM
Ivan
My wire is run correctly and the bulb illuminates with power applied to the socket terminals so I know that end is good. as mentioned, ive tried the headlights in every way possible and no power. Im waiting on a manual that has wiring diagrams but in the mean time if there is a circuit I could check, appreciate it.
Old 01-02-2021, 06:45 AM
Thats the round connector that passes through the left side rear fender to provide brake, signal & running lights correct? I have running lights.
Old 01-02-2021, 06:48 AM
ROW '78 911 Targa
timmy2's Avatar
Photo for you. (From a really bad old harness)
Grey wire with connector is supply to hood lamp.
Check it has a good connection and power when running lights are on.
Dennis
Old 01-02-2021, 02:21 PM
Thanks for the pic. Thats the one I was thinking of. Had that unplugged recently trying to chase a bad ground on the tail light. Dont recall the connector but will take a look tomorrow. Tried to chase it today but the trunk wire loops down past the fuel filter and I cant see anything after that. Pulling on it moves the main trunk harness.
Old 01-02-2021, 07:39 PM
Tags
911sc engine , wires electrical
