1976 911S Targa
Cardboard disc
Greetings! While tinkering in the frunk this disc appeared. Where does it go?
Old 03-21-2021, 04:06 PM
blocks off duct in smugglers box most likely
Old 03-21-2021, 05:11 PM
1976 911S Targa
Okay, I'll take a look in the smuggler's box now.
Old 03-21-2021, 05:19 PM
1976 911S Targa
Nope. Not the smuggler's box. No open duct or anything that needs to be blocked. Thanks for the suggestion.
Old 03-21-2021, 05:24 PM
ROW '78 911 Targa
timmy2's Avatar
Hole in inside fender wall passenger side. Up near dash.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-21-2021, 07:10 PM
It goes dead center under fresh air blower. It is glued in. It goes in open hole in this pix at top center.
Old 03-21-2021, 08:13 PM
Timmy2 is right, right side, under dash, behind right hood hinge.
Lorne m.
83 SC
Old 03-22-2021, 10:08 AM
1976 911S Targa
Thanks for the location suggestions. Since the part was in the frunk I will presume it is dead center under the fresh air blower. I will also check the passenger (right) side up near the dash by the right hood hinge to familiarize myself with the bits and pieces.
Thanks to all.
Old 03-22-2021, 03:56 PM
The small cutout in the piece is to clear the fresh air box drain tube.
Old 03-22-2021, 04:15 PM
1976 911S Targa
I can feel the hole but there is a card board barrier preventing access. It appears that two snaps for the carpet need to be unscrewed, then the card board barrier can be removed, the whole accessed, the card board circle glued, and put back it its proper place.
Thanks for the help.
Old 03-22-2021, 06:12 PM
Isn't this a great resource? So many out there taking time to help others.
Old 03-27-2021, 07:23 AM
