Wer bremst verliert
JohnJL's Avatar
Worst spark plugs ever
I was doing some preventative maintenance to an 85 911 and found the plugs in this condition...the motor was running OK but will obviously benefit from a new set of plugs, wires , rotor and cap. I have never come across plugs in such bad shape...they are Bosch WR70P Platinum of unknown age...one pic below is next to new Bosch WR7DCs
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-12-2021, 03:58 AM
theiceman's Avatar
those plugs look absolutely fine... they are just a different style to your replacements. They live in a harsh environment.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-12-2021, 05:04 AM
LJ851's Avatar
Looks like a typical platinum plug to me, what do you see wrong with it ?
Old 05-12-2021, 05:08 AM
proporsche's Avatar
WR7DC are the correct plugs for your 911 ..if you do not use catalyst you should get W4CC plugs
Ivan
1985 911 with original 501 587 miles...807 226 km
Old 05-12-2021, 05:16 AM
I'm guessing you think the plugs have burned off the electrode, like you see on the new plug?? If so, those platinum ones are different and have no protruding electrode, they look like that when new. So other than being dirty, they look just fine.
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 05-12-2021, 05:23 AM
Wer bremst verliert
JohnJL's Avatar
Huh, all the platinum plugs I recall seeing in the past had fine wire electrodes, I assumed these burned off. They look very different to anything Ive seen before.
In with the WR7DCs.
Ivan, are the W4CC really 3 ranges hotter? Why the difference due to cat or not?
Thanks!
Old 05-12-2021, 05:25 AM
proporsche's Avatar
yes for non cat WR4CC....i have never liked those so called platinum plugs.
I just wonder if you are able to get the WR4cc plugs?
Ivan
correction, i keep forgetting the R
Old 05-12-2021, 05:35 AM
lake wales fla
In with the WR7DCs.
Thanks!
The Bosch plug heat range is higher number is hotter and lower number is colder. The WR7DP is not a true platinum plug and is reflected in the ( cheap) price. Look at the price of a set of say W3DPO which are true platinum and you will see the difference. I agree with retro that other than looking like they have been in there for a while they look fine but also agree they are uneccessary and would just stay with either the WR7DC Bosch or a BPR6ES Ngk Richard
Old 05-12-2021, 06:51 AM
I have an extra set of the WR7DCs that are about 2 months old in the box if you want them. PM me
Old 05-12-2021, 01:01 PM
worst spark plugs ever
I have a 79SC 3.0L stock CIS with MSD 6AL ignition. MSD does not recommend running resistor plugs with the hi voltage ignition system. So, I tried to order the NGK BP6ES plugs to do a tune up. After checking multiple sources (including our host and every auto parts store) to find these plugs I was told they are NLA and I'd have to get the superceded plug NGK BPR6ES, whish is a resistor plug not recommended for hi-voltage ignition systems. So, I have found a source that i can purchase unlimited amounts of the correct non resistor plug for my application. If you're having the same issue maybe I can help if you need that or a different heat range non resistor plug. Thanks, Kip
Old 05-12-2021, 02:50 PM
Yes,
They are the worst spark plugs ever and thank goodness they aren't made any more, at least I think that style is no longer made. The platinum is flush with the insulator and burns away leaving a carbon core in its place. The second problem with the flush electrode is that it does not play well with waste spark systems or any ignition that does not fire negatively from the centre electrode. Expensive, crappy plugs. Fred
Old 05-12-2021, 04:23 PM
Fleming's Avatar
Fred what plug would you suggest for a 2ltr 160HP+ with a MSD 6AL ignition?
Thanks.
Old 05-14-2021, 04:30 PM
Sorry, I do not own a Porsche, but I do know that old style Bosch platinum plug is a misfire waiting to happen. I would also stay away from Champion resistor spark plugs as the resistors used to be weak. Any ignition responds better with low resistance on the secondary side, but you would be best to ask the Porsche owners here what plugs they have run successfully with MSD brand CDIs. Fred
r
Thanks.
Old 05-14-2021, 04:36 PM
Irrationally exuberant
ChrisBennet's Avatar
I like NGK's. My friend was a Bosch Master mechanic (and the head of the Bosch council) and he wouldn't use those "Platinum" Bosch plugs.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-15-2021, 04:27 AM
proporsche's Avatar
this^^^^^^
Old 05-15-2021, 02:32 PM
Jeff Alton's Avatar
Yes, can't recall the last bosch plug we put into a 74-89 911 aircooled motor......
They work very well in the watercooled motors, and I am sure the proper heat range Bosch plug works OK in the aircooled motors too. But not those ****ty Platinum ones...
www.turn3autosport.com
Old 05-15-2021, 09:46 PM
